How do you know what kind of diff you have? - JeepForum.com
post #1 of 7 Old 03-10-2004, 08:32 PM Thread Starter
Gumby1
2014 JK Wrangler
We bought a 96 grand a little while ago and was wondering how do you tell what kind of diff is in the back. I want change all the oils (diffs, transfer case etc) in this thing but on the rear it says to put in the additive if it has a certain diff. Also is their anything special about the atf listed in the owners manual? Or can i use an aftermarket fluid?
Gumby1 is offline
post #2 of 7 Old 03-10-2004, 09:23 PM
greasefingers
greasefingers's Avatar
1994 ZJ
My 94 calls for 75W-90 weight oil. If you are lucky, jeeps have an identification tag which is held on by the pumpkin pan bolts. It will state the part number & gear ratio. A second ID tag is supplied if the Diff has Trac-loc (lmited slip) option.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 7 Old 03-11-2004, 05:15 AM
thunderchooch
thunderchooch's Avatar
Here is a easy way to see if you have the Dana 44 Aluminum in the back, See if the housing is rusting at all, or just scrape the bottom of the pumpkin and wait a day or two and see if it starts to rust. If it doesn't rust it is the aluminum dana 44.
97 Limited ZJ, 7" RE short arm
Kevinz Radiator support and shackles, Tom Woods driveshafts, OME SD-40 steering stabilizer, Cobra CB and PA, Bilstein Shocks, 35" BFG MUD TA KM2's, FM50, Surco Roof Rack, IRO Heavy Duty Steering and more to come soon!!
thunderchooch is offline
post #4 of 7 Old 03-11-2004, 06:52 AM
Rjwrangler
Just go to Jeep.com/customer service and email them. In the email request a build sheet for your vehicle, then provide them with your VIN#. That is all it takes and in less than 3 days you will know every part that went into your Jeep.
I have ttried this on Jeeps as old as 93, it may even work for earlier models.
98 TJ 4.0L Auto
Rubi suspension, 2"BB, 1"BL
33x12.5x15 TrXus MT's
15x8 Rock Crawlers(Black)
Live to Wheel, Wheel to live!
Rjwrangler is offline
post #5 of 7 Old 03-11-2004, 08:34 AM
Swamp Boy
Swamp Boy's Avatar
There is always the magnet test.. As we know the magnet wont stick to aluminium..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #6 of 7 Old 03-12-2004, 08:38 PM Thread Starter
Gumby1
2014 JK Wrangler
Ok, so if its got an aluminum housing its a limited slip diff, and a good old steel housing is an open diff which i can just use normal gear oil with no additive? Thanks guys
Gumby1 is offline
post #7 of 7 Old 03-12-2004, 10:05 PM
Meerkat
Umm, no. If you have an aluminum housing, then you have the Dana 44, but having the Dana 44 doesn't mean you have a limited slip differential. Another consideration is whether or not you have the factory tow package. Having the tow package means you have a 3.73 axle ratio. Which requires SAE 75W-140 Synthetic Gear Lubricant (which none of the autoparts stores I have checked carry). Models with Trak-Lok require an additive. Now, if your rear differential has Trak-Lok, it should have a tag held on by one of the cover bolts that says "limited slip" "Trac-Lok" or similar, however, the tag could simply be missing. The best way, failing finding a tag, is to request a build sheet from Jeep . Simply send them an email with your VIN requesting a build sheet. They will email one back to you, and you will find out all kinds of good stuff about your vehicle. What kind of rear axle you have, the gear ratio, type of trim, etc, etc.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 12:53 PM
To rebuild a diff or not to repair a diff? Anto ZJ Grand Cherokee Forum 10 03-23-2009 04:13 PM
what kind of calipers on my 99? kilabeez0 ZJ Grand Cherokee Forum 10 08-26-2007 10:39 PM
What Kind Of Gas? illz302 ZJ Grand Cherokee Forum 10 05-18-2005 10:27 AM
Kind of want to get a GC kairo ZJ Grand Cherokee Forum 12 07-01-2004 12:23 PM
