How do Iset my timing on my Jeep? - JeepForum.com
post #1 of 7 Old 08-31-2007, 01:36 PM Thread Starter
02Lightning
I know how to set it but is there something you disconnect to set base timing?
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 119,500 miles
02Lightning is offline
post #2 of 7 Old 08-31-2007, 02:27 PM
rm2001wj
rm2001wj's Avatar
I'm pretty sure that the "base" timing is programmed into the PCM and there is nothing much you can do about it. The PCM adjusts the timing, as needed, based on various sensor inputs and its programming. Timing adjustments different from those produced by the PCM can be made by intercepting the CPS signals, making changes, and then sending them on to the PCM. Also it's possible to intercept the PCM signal going to the coil and then add a delay.
What are you thinking about doing?
rm2001wj is offline
post #3 of 7 Old 09-01-2007, 03:32 PM Thread Starter
02Lightning
Make sure my base timing is set. I know on a 88 mustang I use to have you would pull a plug to get base timing. I know on early 90's GM cars you had to jump a plug under the dash. I want to put a timing light on my jeep and see where base timing is and adjust it if needed. I'm about 95% sure you can change your base timing on a jeep. All you have to do is move the distributor, I just want to be sure I'm looking at base timing with no advance and I need to know how to eliminate the advance before I mess with it.
post #4 of 7 Old 09-01-2007, 03:43 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Putting a timing light on your engine will tell you where your timing stands as it is right now. Compare that to what the manual says should be the correct timing for your engine.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 7 Old 09-01-2007, 04:40 PM
rm2001wj
rm2001wj's Avatar
The camshaft position sensor is in the distributor and its signal is used for timing the injector pulses. If you try to move the distributor from its factory position the injector timing gets messed up. Also, the cam position sensor is used to tell the PCM which cylinder is #1. As I mentioned earlier, the crankshaft position sensor is used for ignition timing. It's possible to ream out the bolts holes and move it a little for a minor timing adjustment. Usually the CPS is so hard to get to that hardly anyone would try that.
Still, let us know if you have any success.
rm2001wj is offline
post #6 of 7 Old 09-01-2007, 06:33 PM Thread Starter
02Lightning
Maybe I stand corrected, sounds like I can't move the distributor like old school cars then?
post #7 of 7 Old 09-01-2007, 06:35 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Correct the distributor does not rotate
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
Timing mjt252 ZJ Grand Cherokee Forum 3 02-11-2009 03:32 PM
Jeep rebuilt engine timing issue... Shaunhudgins ZJ Grand Cherokee Forum 1 05-30-2008 07:17 PM
Timing a new Jeep Order LuauFish WK Grand Cherokee & XK Commander Forum 3 10-27-2007 05:24 PM
timing ??? sdr93 ZJ Grand Cherokee Forum 3 12-11-2005 06:44 AM
Jeep Timing? spichman510 ZJ Grand Cherokee Forum 1 03-24-2003 08:54 PM
