How do I swap analogue odometer reading between old and new speedos? - JeepForum.com
post #1 of 9 Old 03-10-2012, 12:35 PM Thread Starter
AVR2
If you have to replace a speedo, how do you transfer the (analogue/mechanical) odometer reading? Can you actually swap the odometer itself between speedos, or do you have to manually adjust each digit on the new odo? If the latter, does it require special tools?
AVR2 is offline
post #2 of 9 Old 03-10-2012, 12:41 PM
Snap-on
this question makes no sense to me i do not understand what you are saying
Snap-on is offline
post #3 of 9 Old 03-10-2012, 01:29 PM Thread Starter
AVR2
My speedo needle is broken. I will get a new speedo from a junkyard. When I do, the reading on its built-in odometer will obviously not be the same as the reading on the odometer of my faulty speedo. I will need to make the odometer reading on the new speedo match the reading on the old one so that the correct mileage reading stays with my ZJ. How do I do this?
Can I swap the odometer assembly from the old speedo to the new, or do I just have to adjust each digit manually on the new speedo to get the odometer reading to match the old one?
AVR2 is offline
post #4 of 9 Old 03-10-2012, 11:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Dealer process only.
ratmonkey is offline
post #5 of 9 Old 03-11-2012, 12:36 AM Thread Starter
AVR2
I have to take the new speedo to the dealer so that they can manually turn each digit on the odometer to match the old one?
AVR2 is offline
post #6 of 9 Old 03-11-2012, 03:00 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You can't just turn them.
Should cost half an hour labor.
post #7 of 9 Old 03-11-2012, 04:32 AM Thread Starter
AVR2
No offence intended, but I have to say that I'm skeptical that it really is a dealer-only job. When I get my new speedo I'll try disassembling the old one to see if the odometer is removable and swappable; it may just be a matter of a few screws. If you're right, I'll allow you to say "I told you so"
AVR2 is offline
post #8 of 9 Old 03-11-2012, 10:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I did some digging for you, you can't reset the odometer in manual gauges after 1991. They went to a tamper proof design.
post #9 of 9 Old 03-11-2012, 10:57 PM Thread Starter
AVR2
OK, thanks. I'll check with the dealer to see if they still offer this service and how much they'll hit me for it.
AVR2 is offline
Odometer milage reading question anderob ZJ Grand Cherokee Forum 4 03-03-2012 02:46 PM
computer replacement-odometer reading nelsonstudios ZJ Grand Cherokee Forum 6 02-28-2011 09:37 AM
odometer Paora01 ZJ Grand Cherokee Forum 1 01-16-2006 04:33 AM
95 - Oil Pressure Reading, Constant Reading EnolaEngineerGC ZJ Grand Cherokee Forum 1 04-08-2005 04:54 PM
odometer reading backwards???? 93 ZJ help... eastman ZJ Grand Cherokee Forum 15 08-13-2004 11:51 AM
