How do I stop my soundbar from bouncing? - Page 2 - JeepForum.com
post #16 of 17 Old 04-27-2013, 12:04 AM
vonericsen
Good luck! I wish I could have been more helpful! (I should have written the item number/part number down back when I did this..) Post the part number when you find the right one so others will know.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #17 of 17 Old 05-07-2013, 09:24 PM Thread Starter
Fasttommyv
The thread of the mounting stud is 10-32.
I finally got something that works. The home improvement store's Tee nuts didn't have a long enough barrel to reach the mounting stud, but mcmaster carr did. Item #90594A023 had the longest barrel that I could find. They make you buy a qty of 50 but it's still less than $10. The nut is just barely long enough to reach the stud and will require some finessing to get it going, but you should eventually get a few turns on the threads and secure the sound bar. Not the most elegant solution but it should work....
Hope this helps
Fasttommyv is offline
