How do I set timing on 2001 grand cherokee 4.0 - JeepForum.com
post #1 of 9 Old 09-10-2009, 04:04 AM Thread Starter
jeepdudeuk
I have just fitted a new cam to my 4.0 2001 grand cherokee (with coil packs).
My mechanic marked the gears before removal and we have reinstaled in the same position and replaced the cam sensor in the same position (we think).
How do you set the timing? will it run ok?, does the computer auto set the timing for me?
Any help would be great
Thanks
Jeepdudeuk
jeepdudeuk is offline
post #2 of 9 Old 09-10-2009, 04:10 AM
BigE3
Thanks
Jeepdudeuk
I think as long as your TDC #1 and cam is lined up correctly it should fire up. I may be corrected.
I like my Jeep, just like my women. 'Loose and Flexible'
BigE3 is offline
post #3 of 9 Old 09-10-2009, 08:07 AM
xJoshxx
2012 WK
with the newer GC the computer CONTRols EVERY thing
just make sure u set the timing chain at TDC and ur good to go
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #4 of 9 Old 09-10-2009, 08:36 AM
tsconver
2003 WJ
if you removed the distributor (or what used to be which is now just the cam position sensor) then you have to use a DRBIII to resync the computer for fuel injection timing with the cam timing. You can get it close but you have to use the scan tool to set it correctly. No other way to do it. Probably $50 to $100 at a dealer to set it correctly.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #5 of 9 Old 09-11-2009, 03:24 AM Thread Starter
jeepdudeuk
Ok if it runs fine when rebuilt (we got the gears on the cps lined up), then will I still need to set the computer at the stealers!
post #6 of 9 Old 09-11-2009, 07:18 AM
tsconver
2003 WJ
yes you still need to go to the dealer to get it all synced up, you may have got lucky and it is right but it could be off and you will either be late or early with the injector pulses. this can cause it to be a little rich or a little lean and will degrade your fuel economy.
A few goodies
2006 Red Liberty
tsconver is offline
post #7 of 9 Old 09-14-2009, 03:52 AM Thread Starter
jeepdudeuk
can i twist the cam possition sensor to get it somewhere near, like you would a distributor?
post #8 of 9 Old 09-14-2009, 10:40 AM
tsconver
2003 WJ
that is how you adjust it, but you need aa DRB3 scan tool so you can watch the waveforms on teh cam sensor and the fuel injectors and sync those up. Otherwise it would be like turning a distributor without haveing a timing light to see the effect of it on the ignition advance.
A few goodies
2006 Red Liberty
tsconver is offline
post #9 of 9 Old 10-20-2009, 01:35 PM Thread Starter
jeepdudeuk
It is using double the amount of fuel and has power loss at midrange, could that be because the computer needs a (re sync), I have a specialist local with the drb3 but not sure he knows what to do! How do you re sync the computor with the drb3 is it just timming set up ?
1 Love
Help Please! Timing chain in 2000 grand cherokee 4.7 aziziy WJ Grand Cherokee Forum 10 05-10-2015 03:19 PM
1997 grand cherokee timing johnny3524 ZJ Grand Cherokee Forum 0 07-26-2009 06:12 PM
2001 Grand Cherokee 4.7 crazycardfan1 ZJ Grand Cherokee Forum 9 01-04-2009 09:41 AM
95 grand Cherokee timing chain..bent valves? dungbeetle ZJ Grand Cherokee Forum 1 12-20-2005 04:57 PM
Any opinions on 2001 3.1 TD Grand Cherokee? Case WJ Grand Cherokee Forum 2 03-22-2002 06:21 AM
