How do I replace the fog light bulb? - JeepForum.com
post #1 of 6 Old 11-29-2009, 09:45 AM Thread Starter
KHoff90
My passenger side fog light burnt out on me and now I can't figure out how to open it up to replace the bulb. I've unscrewed the 2 screws on the plastic piece under the housing, but nothing will budge. I don't want to force anything and end up breaking it so before I did that I figured I better ask you all.
Anyone know how to get to the bulb so I can change it out?
KHoff90 is offline
post #2 of 6 Old 11-29-2009, 10:47 AM
MiniTubbedNova
the cover that you unscrewed is probably just on stuck on, pry it off nicely, then there is a rubber gasket pull that out then there are two spring tyoe clips, push those down and toward ewach other and they will unhook them selfs, then in plig the wire and reverse process
MiniTubbedNova takes no responsibility for the comments above...
1970 Nova SS -355-Th-350
1996 Jeep Grand Cherokee - 4.0L-
IRO 4.5" - 33" MT's
Originally Posted by -n8man1068
Jeeps don't get stuck. They just take a nap when they're tired of being awesome.
MiniTubbedNova is offline
post #3 of 6 Old 11-29-2009, 10:48 AM
MAUSS
I assume that the fog lamp on the '97 is like the one on the '96. Once you've removed the 2 screws, pop off the plastic plate on the bottom with a screwdriver (it's just stuck from the heat after all these years)... you shouldn't break anything. There's a clip holding the bulb socket in place under the plate, unclip it and pull the socket out. Don't handle the new bulb with your fingers... the oils will cause it to burn out prematurely.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #4 of 6 Old 11-29-2009, 10:57 AM Thread Starter
KHoff90
Ok thanks for the help fellas. I'll give it a go here after the Skins - Eagles game.
KHoff90 is offline
post #5 of 6 Old 11-29-2009, 11:05 AM
HELMET
X2 on Maus^, , And Mini, loose the mittens dude
HELMET is offline
post #6 of 6 Old 10-18-2011, 12:28 PM
gwood312
Very good instructions.
gwood312 is offline
1998 ZJ back up light bulb, help find the right bulb part # NeverL8 ZJ Grand Cherokee Forum 1 02-06-2010 06:23 PM
Which bulb do I use here and how do I replace it? Crewdude007 ZJ Grand Cherokee Forum 5 12-08-2009 12:07 PM
Center brake light is out. How do you replace the bulb? 05WKinPA WK Grand Cherokee & XK Commander Forum 5 06-27-2008 01:00 PM
How to replace this bulb, manual doesn't show Jon08JK ZJ Grand Cherokee Forum 3 11-27-2007 07:39 PM
replace turn signal bulb eprovenzano ZJ Grand Cherokee Forum 3 01-17-2006 08:29 AM
