How do I replace drive side Window - JeepForum.com
post #1 of 2 Old 04-10-2012, 03:40 PM Thread Starter
BigEag205
hello, I have to replace doors on my jeep along with a window. Does anyone have a thread or step by step on 1) replacing the window on a driver's door. and 2) where all the little metal rods for the door locks and things connect. There's 2 and I'm not sure where they hook up.
BigEag205 is offline
post #2 of 2 Old 04-10-2012, 04:40 PM
Technohead
Roll the window down 1/2 way then remove the door panel. Through two access holes (if you rolled the window down far enough) you will see to bolts holding the window into the channel. Remove them then pull the window up and out of the door.
You can figure out how to deal with the lock linkage.
-Eric
Technohead is offline
How to replace a window regulator mwalters2 WK Grand Cherokee & XK Commander Forum 8 05-28-2013 10:10 AM
To replace the drivers window charlesshoults ZJ Grand Cherokee Forum 2 12-21-2010 09:41 AM
How much to replace window? stanton3 WK Grand Cherokee & XK Commander Forum 1 05-10-2010 06:01 PM
how to replace drivers window? joshisurdaddy ZJ Grand Cherokee Forum 2 06-11-2007 08:05 PM
Passenger window smashed! How to replace?? SSick22 ZJ Grand Cherokee Forum 2 03-11-2007 06:05 PM
