How do I pull trouble codes? - JeepForum.com
post #1 of 3 Old 08-03-2009, 11:57 AM Thread Starter
steve718
It's a '97 ZJ.. I read something about holding the trip reset down but I don't seem to get anything
is there a way to pull the codes w/o a scanner?
steve718 is offline
post #2 of 3 Old 08-03-2009, 02:13 PM
Lil_Ape
Try and turn the key to the ON position(don't start the jeep), then back off. Do that about three to four times and the codes might show up in the odometer. My '02 does it but i don't know if a '97 will.
'02 WJ limited / 4.7L H.O. V8 / 2WD
Lil_Ape is offline
post #3 of 3 Old 08-03-2009, 02:30 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I believe it is on-off-on-off-on. Should work on the 97. The codes will show in the odometer as long as the light is on. Otherwise it will just say "done" Write down the codes and come back here to search them.
~James
ezflip is online now
'97 GC Laredo-How to pull codes? goul6891 ZJ Grand Cherokee Forum 2 07-19-2009 07:55 PM
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 02:59 PM
How do i pull up the HVAC codes... mike4089 ZJ Grand Cherokee Forum 13 01-29-2009 11:26 AM
How to Pull Transmission Codes? julesab ZJ Grand Cherokee Forum 1 02-22-2005 05:57 PM
pull codes??????? spichman510 ZJ Grand Cherokee Forum 12 12-08-2004 09:51 AM
