How do I order a 4 inch offset rim? - JeepForum.com
post #1 of 9 Old 12-05-2015, 07:23 AM Thread Starter
mkunkel20
I have been looking at rims on tire rack for my 97 ZJ Laredo. I wanna grab a set of 16x8 ultras. How do I order with a 4 inch offset?
mkunkel20 is offline
post #2 of 9 Old 12-05-2015, 07:45 AM
mcgyvrZJ
wheel backspacing is listed in the detailed description of each wheel..
Simply click on the wheels and look for one with 4"
mcgyvrZJ is offline
post #3 of 9 Old 12-05-2015, 08:14 AM
tjcustomranger
You may be able to refine the results and make ot show only 4" backspace rims
tjcustomranger is offline
post #4 of 9 Old 12-05-2015, 08:47 AM
PolkaPower
Look for back space instead of offset.
PolkaPower is offline
post #5 of 9 Old 12-05-2015, 06:44 PM Thread Starter
mkunkel20
Thanks guys I just noticed in the description where it has backspacing. The ultra rogue 16x8 i'm looking at has a 4.8 inch back spacing. This is the first vehicle I have done any type of lifting or anything to so i'm pretty ignorant at this point.
post #6 of 9 Old 12-06-2015, 02:41 AM
PolkaPower
3.75-4" is all you need.
post #7 of 9 Old 12-06-2015, 08:13 AM
murfnamedsmurf
I'll second what has already been posted. Offset and backspacing are related, but in this case you are looking for backspacing. This is not a guarantee, but in general people usually focus on offset when discussing car wheels, whereas particularly for off roader wheels the focus is generally backspacing.
murfnamedsmurf is offline
post #8 of 9 Old 12-06-2015, 11:17 AM
robrtsmtn
I'm sure someone will point out if I am wrong, but as I recall on an 8 inch wide rim. 0 offset is a 4 inch backset.
1993 ZJ 4.0 3.5 inch lift
1993 ZJ 5.2 V8, this Spring project
robrtsmtn is offline
post #9 of 9 Old 12-06-2015, 03:29 PM
kg6mov
Hears the voices
kg6mov's Avatar
Correct.
kg6mov is offline
