How do I know if its my water pump? - JeepForum.com
post #1 of 9 Old 11-06-2005, 04:12 PM Thread Starter
grasp
97 gc 5.2 ---Lent my jeep to my friend and and got a call 2 hours later that it was spewing coolant. I didnt get there till the car was cool so i dont know if it overheated. Waterpump still spins fine but alot of coolant was coming from where the pump bolts in. The waterpump still spins fine and seems ok to me. Is it possible that the seal went bad and thats all that needs to be replaced.
Also what is the best way to replace the hose that goes under the ac pump from the water pump?
Thanks
grasp is offline
post #2 of 9 Old 11-06-2005, 04:40 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I guess you will have to fire it up and wait to see exactly were that water starts leaking from. Your water pump is eight years old. It probably can not last much longer, even if it is not the issue.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 9 Old 11-06-2005, 05:13 PM Thread Starter
grasp
I have checked with the car on. It leaks from where the pump bolts in. Is this necessarily my water pump though?
grasp is offline
post #4 of 9 Old 11-06-2005, 05:23 PM
greasefingers
1994 ZJ
It typically does not leak from around the housing unless the housing is warped. There are two weep holes for the water pump. If the internal bearing is bad then coolant will leak from these holes. Either way you will need a new water pump.
Cheers Steve
post #5 of 9 Old 11-06-2005, 06:25 PM Thread Starter
grasp
Now the pulley wont pull off. I used a torch and a mallet. Any tips?
grasp is offline
post #6 of 9 Old 11-06-2005, 07:15 PM
greasefingers
1994 ZJ
A torch will not help. The geometry of a circle is working against you. You cannot pull directly straight out, without a pulley puller. Jeep pulleys are very cheaply made, and can bend easily. Soak the sh_t out it over night and try to drive two wedges behind it. Something like door-stop wooden wedges can sometimes work. Make the wedges out of 2x4s if you have to. But the pullers are really cheap to purchase and you can use them on many different parts.
Cheers Steve
post #7 of 9 Old 11-06-2005, 07:52 PM Thread Starter
grasp
I went to my local advance to see if they had one i could borrow. They told me they had ones to rent or sell but none I could use. Stupid -=-=-=-= i will take my business elsewhere. Gonna go tomorrow to another store. Thanks
grasp is offline
post #8 of 9 Old 11-06-2005, 09:11 PM
coonash
coonash's Avatar
I 'rented' a puller for my fan clutch at a parts store her in town. Charged me credit card for it, when I returned it the next day they refunded my card. Very painless. If it had been a better quality puller I'd probably would have kept it.
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #9 of 9 Old 11-14-2005, 11:08 PM
kentman
kentman's Avatar
2006 XK Commander
I would not take the disk off of the shaft. The pump is very cheap, and it comes with a new disk. If you apply pressure on the shaft, then it will surely leak in the future. I suspect that that is what is leaking now via the weep hole. I would hate to get it back together only to find that you really need a new pump. Prophylactic pump replacement is a good thing.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
Bad water pump? wickerham ZJ Grand Cherokee Forum 9 12-02-2009 01:55 AM
Water Pump $$$$ Tbauer44 ZJ Grand Cherokee Forum 4 10-27-2009 09:16 PM
4.0L Water Pump Blkdvll ZJ Grand Cherokee Forum 7 10-04-2009 09:07 PM
Water Pump ??? 5.2 V8 trickle26 ZJ Grand Cherokee Forum 8 04-02-2005 11:45 AM
