How do I get my serpentine belt off? 4.0L - JeepForum.com
 1Likes
post #1 of 21 Old 01-22-2006, 04:19 PM Thread Starter
02Lightning
usually they have a spring loaded idler pulley, didn't see one that looked springloaded?
1995 Jeep Grand Cherokee Limited 4.0L NP249 Transfer Case, 42RE, 212,000 miles
02Lightning is offline
post #2 of 21 Old 01-22-2006, 04:36 PM
kentman
kentman's Avatar
2006 XK Commander
On my '97, there is no spring loaded pulley. I believe that there is just an adjustment bolt near the power steering pump.
'06 XK Limited, 5.7L, QD II, Black, 155K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 118K
kentman is offline
post #3 of 21 Old 01-22-2006, 05:03 PM
-Joe-
-Joe-'s Avatar
Gota loosen the power steering pump to get the belt off..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 21 Old 01-22-2006, 05:36 PM
Turbonut
Yup, bolts on front and rear of the pump. There is a jamnut and threaded rod under the pump you turn after the pump bolts are loosened. It will move the pump in and out. Sometimes the pump needs a little assistance to move as you're backing off the threaded rod.
Turbonut is offline
post #5 of 21 Old 01-22-2006, 05:39 PM
zjay
If it's the one I'm thinking of, don't miss the 2nd bolt on the back of the pump- it's lower and harder to see.
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #6 of 21 Old 01-22-2006, 06:44 PM
greasefingers
greasefingers's Avatar
1994 ZJ
There are five bolts/nuts that need attention. Loosen the two mounting bolts on the rear of the PS pump (top & bottom). One bolt in the front (top) & one nut in the front (bottom). Only then can the long adjusting/tension bolt be turned to remove the slack of the belt. Even with these bolts loose, the pump may need some physical handling in order for it to move.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 21 Old 01-22-2006, 06:52 PM Thread Starter
02Lightning
Thanks guys, I was afraid of that.... But no big deal, geese... I would think they would have broke into the 80's on this by now.
post #8 of 21 Old 01-22-2006, 10:49 PM
-Joe-
-Joe-'s Avatar
I think if I keep this jeep long enough to replace the engine Im going to retrofit the newer style belt tensioner.. Cant be that hard..
- Joe -
-Joe- is offline
post #9 of 21 Old 01-23-2006, 09:40 AM
rschunk
rschunk's Avatar
Be glad the tensioner is so easy. I've changed serpentine belts with tensioner pulleys that have taken two guys and a crowbar.
"Mean Green"
4.0 inline 6
3" BDS Suspension lift
ARB bumper with
T-Max 9000# Winch
Optima Yellow
JKS Swaybar Quick Disconnects
30x9 Dunlop Mud Rovers
Rocky Road Rockrails (Great rails, lousy shipping)
GPS Street Pilot
175,000 miles & still going!
93 Green GCL
Green Jeep Club Member #163
check out the pictures..
Also a 'Graphite' 2002 Grand Cherokee Laredo. Graphite Jeep Club Member #1
rschunk is offline
post #10 of 21 Old 01-23-2006, 01:02 PM
Kcolg
Or like some GM passenger vehicles like the Park Avenue and Bonneville where a motor mount has to be undone as well.
1994 ZJ - 4.0 - 242 - 4.5" RE lift - 32" Maxxis Bighorns - 4.11 gears - Super 35 axle - Ected lockers front and rear - On Board Air - JKS Quicker Disco's - ARB front - engine/TC/Gas tank skids - home made sliders - a little of Kevins stuff
Kcolg is offline
post #11 of 21 Old 01-23-2006, 07:59 PM
LTD 318ZJ
Just loosen the PS pulley bolt and then the long bolt on the back
You don't even need to go to all that trouble to get the belt off. Just slide the belt off of the idler pulley so you can get some slack.
puubear98 likes this.
LTD 318ZJ is offline
post #12 of 21 Old 01-23-2006, 08:13 PM
greasefingers
1994 ZJ
Always there is some combination of pivots and slots on the mounting bracket(s). At least on the 1993 to 1995 4.0 L engines there is one upper pivot and three other slots. Only if all four of these bolts are loose, will the power steering tensioner actually work. Mine has no idler pulley tensioner. Just two idlers with thru bolts mounting them onto the block. Some have idler-tensioner pulleys.
Cheers Steve
post #13 of 21 Old 01-23-2006, 08:34 PM Thread Starter
02Lightning
Thanks again guys
post #14 of 21 Old 07-17-2013, 12:36 AM
Tunie
1995 Serpentine Belt JGCL
Thank you, Thank you, to ALL of you fine folks that get on here and take the time to help out us mere mortals with our Jeep probs. Absolutely had to loosen PS pump to replace serpentine belt on our 95 Jeep GCL. The 411 provided by all of you was and is immeasurable as it has literally saved my family lots'o $$$$. Seriously!!! You guys and gals (I suppose there are some women on here...I am one) have taught me how to properly clean heater hoses so as to have heat in the winter months (worked like a charm!), fix my back hatch (exactly the way you said it would!). And, now, because of this thread, my husband (that is a musician) is confidant that he can replace the serpentine belt. YOU GUYS ROCK!!!! Thank you, Thank you, from the bottom of my heart....
QUOTE=greasefingers;1793783]Always there is some combination of pivots and slots on the mounting bracket(s). At least on the 1993 to 1995 4.0 L engines there is one upper pivot and three other slots. Only if all four of these bolts are loose, will the power steering tensioner actually work. Mine has no idler pulley tensioner. Just two idlers with thru bolts mounting them onto the block. Some have idler-tensioner pulleys.[/QUOTE]
Tunie is offline
post #15 of 21 Old 07-17-2013, 12:01 PM
dnuccio
shoulda had a v8, they have automatic spring loaded tensioners
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 10:41 AM
Serpentine Belt Bricolage ZJ Grand Cherokee Forum 1 04-13-2008 04:24 PM
serpentine belt chadburgwald ZJ Grand Cherokee Forum 1 08-23-2006 06:34 AM
Serpentine belt on WJ. rrubio ZJ Grand Cherokee Forum 9 01-06-2006 07:50 PM
Do i need a new serpentine belt? 98ZJBlack ZJ Grand Cherokee Forum 7 10-06-2004 11:55 AM
