How do I find all the Vacuum Lines? - JeepForum.com
post #1 of 7 Old 02-18-2009, 08:55 PM Thread Starter
br3ds0x
Have the problem where the air is only coming out of the defrost vents. After searching around it appears to be the vacuum lines that have a leak. The problem I am having is finding exactly where the lines are in the car so I can check them. Could anyone help me find them? Thanks a lot
br3ds0x is offline
post #2 of 7 Old 02-18-2009, 09:14 PM
sullivanpunk
Im in the same boat except my a/c&heat work fine, but my cruise control dosen;t any someone told me I could still have a vacume leak. The best thing I could come up with is just take the time and check every vacume line you can find.
P.S. its not a car its a Jeep
2000 Grand Cherokee Laredo, V8 4.7, Quadratrac 2 TC, 255/70/16 Uniroyal Liberator AT tires with stock height, Flowmaster Super 40 muffler
sullivanpunk is offline
post #3 of 7 Old 02-18-2009, 09:29 PM
dmolaver15
i had the same problem, i found one of the vaccuum lines, just under the throttle body was disconnected, i popped it back on and what do ya know? everything worked again..
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread:
dmolaver15 is offline
post #4 of 7 Old 02-18-2009, 09:33 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Most of those lines run from the back side of the engine, along the firewall to the passenger side fender, up to the front of the fender, under the battery box.
It's common for ppl to find their vac leaks under the battery box...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 7 Old 02-18-2009, 09:58 PM
UofOJeeper
I see you finally found Jeepforums!
Hopefully some of the WJ experts will be able to help out. Let me know if you have any other questions! I would check but, bf.c is down right now...
-Nick
1998 Laredo Special Edition V8
Toyo Open Country A/Ts - 245/70/R16
242 Swap
"A man who asks no questions, rarely has any answers"
UofOJeeper is offline
post #6 of 7 Old 02-18-2009, 10:07 PM Thread Starter
br3ds0x
-Nick
Thanks
Ya that seems to happen often
br3ds0x is offline
post #7 of 7 Old 02-18-2009, 11:12 PM
sullivanpunk
I have taken my battery and battery tray out and found a vacume line completly seperated repaired it and looked at everything I could find and no more leaks. Like stated above I guess I will check the obvious spots around the intake tomorrow between shifts
sorry to the first person..im not trying to hi-jack your thread
sea foam and vacuum lines kevinboh ZJ Grand Cherokee Forum 2 07-22-2009 06:37 AM
5.9 intake manifold vacuum lines Texas ZJ1 ZJ Grand Cherokee Forum 15 05-18-2009 09:24 PM
Vacuum Leak 1997 Laredo Dash Vacuum Lines twmattox ZJ Grand Cherokee Forum 4 11-17-2008 08:34 AM
vacuum lines chewed through!! need diagram! Sontizzle ZJ Grand Cherokee Forum 4 08-02-2008 08:12 PM
vacuum lines coming off---WHY? 1bighldog ZJ Grand Cherokee Forum 9 05-21-2007 05:01 AM
