how do i disable ABS? - JeepForum.com
post #1 of 55 Old 12-16-2009, 12:35 AM Thread Starter
ronsaun
2003 WJ
i hate ABS!!!!!!!!! i drive in deep snow and ice all winter. when i brake for some reason i get ABS "very" often, then i slide, albeit straight. i attribute this to the ABS reaction to the extremely slippery conditions. but, it takes way longer to completely stop as opposed to just regular brakes. i want to turn them off. i know all about the handling differences and i want them OFF!!!!!!!!
are there any electronic or mechanical issues that would develope other than the trouble light that would create additional problems and/or expense(modifications)? i would appreciate any FACTUAL experience. thanks ron
ronsaun is offline
post #2 of 55 Old 12-16-2009, 12:36 AM
Virmagicus
Virmagicus's Avatar
Pull the relay.
Jeff
Virmagicus is offline
post #3 of 55 Old 12-16-2009, 12:53 AM
Nosights
Pull the fuse...it's just that easy. It should be in the power panel near the battery on the fender (rectangular box if I remember right.)
Nosights is offline
post #4 of 55 Old 12-16-2009, 12:58 AM
Virmagicus
Virmagicus's Avatar
It will feel like that old Jeep you used to have lol. No harm no foul.
Jeff
post #5 of 55 Old 12-16-2009, 01:06 AM Thread Starter
ronsaun
2003 WJ
thanks to all. that is good news. that way if i do want them back i can just put the fuse back in. ron
ronsaun is offline
post #6 of 55 Old 12-16-2009, 02:00 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you kill power to the abs system you lose your speedometer. The WJ gets its speed signal through the abs controller. The only way to stop the abs system from working while keeping your speedometer is to remove one of the front sensors or otherwise make it inoperable.
ratmonkey is offline
post #7 of 55 Old 12-16-2009, 02:17 AM
JrMechanic
That ABS pump is able to pump the brakes much quicker and more efficiently than you ever could. Saying that non ABS equipped Jeeps stop better in slippery conditions would be ignorant.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #8 of 55 Old 12-16-2009, 02:18 AM
Virmagicus
Virmagicus's Avatar
I'm sure ronsauce has the GPS. I have a feeling he won't care anyway
Jeff
post #9 of 55 Old 12-16-2009, 02:22 AM
Virmagicus
Virmagicus's Avatar
It's an old school thing ... & there is no stopping on ice anyway. Even with ABS. I must be an ignoramous
Jeff
post #10 of 55 Old 12-16-2009, 03:07 AM
Technohead
There is absolutely NO WAY you will be able to stop the vehicle quicker than a properly functioning ABS system.
Another consideration is insurance. Chances are your insurance policy is based on having ABS. Deactivate ABS and then get into an accident . . . don't be surprised if you are facing a big out-of-pocket payout. Real world cases of this happening have been reported on other forums.
-Eric
Technohead is offline
post #11 of 55 Old 12-16-2009, 03:11 AM
Greengc4x4
Sounds to me like your ABS is not functioning properly. I would look into fixing the problem rather than disabling it.
Greengc4x4 is offline
post #12 of 55 Old 12-16-2009, 03:50 AM
Wizardstsi
What you guys are saying about never being able to outbrake the ABS unit is true AND false.
In the dry and wet, sure the ABS wins all the time. But throw in gravel or snow or any other loose surfaces and ABS actaully INCREASES stopping distance.
"In gravel, sand and deep snow, ABS tends to increase braking distances. On these surfaces, locked wheels dig in and stop the vehicle more quickly"
Took that from wiki but it's been written in many other places.
Wizardstsi is offline
post #13 of 55 Old 12-16-2009, 06:09 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
The slight decrease in stopping distance is due to buildup of "stuff" be it sand, gravel, snow in front of the tires and acting like a chock block. The distance differance is pretty minimal and one good thing about ABS is you stop in a straight line.
I'd leave it alone.
Whybu1 is offline
post #14 of 55 Old 12-16-2009, 04:10 PM
tsconver
2003 WJ
as mentioned if you pull the power to it you will loose your speedometer and cause a constant check engine light. Here in NC it would not pass inspection with a CEL on.
Also the odometer will not work any longer and that will impact your ability to resell it.
Finally, the WJs do not have a brake proportionating valve, the front to rear proportionating is controlled by speed, braking and road conditions through the abs pump. So with out the ABS pump it will be split 50/50 front to rear and will negatively impact your stopping distance.
Again if you get in an accident insurance may hang you out to dry if they figure out you intentionally disabled the ABS.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #15 of 55 Old 12-16-2009, 04:15 PM
JrMechanic
I'd leave it alone.
Yup, that's one of the largest benefits to ABS, is being able to stop wherever you point the wheels. When you lock up your brakes, you have no steering control. If you're on a slick surface and mash the brakes (with ABS), you retain at least some control of where your vehicle is going.
How To : Disable your alarm on your ZJ CLNinja ZJ Grand Cherokee Forum 227 08-06-2016 02:13 PM
how to disable abs 2blu2 ZJ Grand Cherokee Forum 12 08-25-2009 11:52 AM
How to Disable ABS 98 ZJ? psychade ZJ Grand Cherokee Forum 12 06-20-2008 02:45 PM
How to disable DRL on 96 ZJ ??? Murdered96grand ZJ Grand Cherokee Forum 10 03-24-2008 02:48 PM
Disable start jjag721 ZJ Grand Cherokee Forum 1 03-17-2006 11:03 AM
