how do i clear out DTC codes? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > how do i clear out DTC codes?
XJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-27-2008, 07:56 PM   #1
MEinSoCal
from searching, i was able to learn how to read CEL codes.
Meh...
MEinSoCal is offline   Reply With Quote
Unread 10-27-2008, 10:14 PM   #2
elmer_fud
you need a code reader, of to cycle the ignition 50 times after the problem is fixed. If you clear it with a reader, it will store a code cleared code for 50 cycles or something though due to emissions requirements
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Unread 10-28-2008, 07:05 AM   #3
rm2001wj
Some fault codes disappear after 3 starts (if not sooner) when the problem is fixed. Whether fixed or not, disconnecting the battery for a while will erase the codes. However, if the problem is not fixed, the code or codes will come right back.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
