How do I check the differential fluid... - JeepForum.com
post #1 of 4 Old 03-01-2003, 09:40 PM Thread Starter
LouisC9999
...on my 1997 Grand Cherokee?
Can someone post or point me to a how-to web site? Search yielded no results.
2004 Grand Cherokee Limited
LouisC9999 is offline
post #2 of 4 Old 03-01-2003, 10:54 PM
Swamp Boy
Swamp Boy's Avatar
You dont need a web site just take out the plug and put in your
finger if you feel oil you have oil . Fill fluid until it is level with your
plug. That is all.
The plug is easy to find its in the middle of your diff.
Just in case you didnt know that..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 4 Old 03-02-2003, 12:38 AM
ChrisinVA
Not sure about your case, but on mine (242) there are two bolts. The bottom one is for the drain, the top for fill/check. Like he said, just stick your finger in there to see if it's topped off. BTW, can't hurt to change it while you're at it...just get a hand pump and put some fluid in.
ChrisinVA is offline
post #4 of 4 Old 03-02-2003, 08:45 AM
Stocker
Originally posted by ChrisinVA can't hurt to change it while you're at it...just get a hand pump and put some fluid in.
Check your owners manual (you have one in the glove box, right?) for the type of gear oil (weight, grade, synthetic?) to get. Drain or suck out the old, pump in the new - until level with the bottom of the fill plug (as posted above) when parked on level ground. Easy!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
Differential Fluid? adgjqetuo ZJ Grand Cherokee Forum 31 07-22-2017 04:55 PM
HELP with differential fluid!! vn712 ZJ Grand Cherokee Forum 6 09-26-2009 07:34 PM
Differential Fluid Euclid537 ZJ Grand Cherokee Forum 8 07-03-2008 12:24 PM
Differential Fluid UTChavok ZJ Grand Cherokee Forum 18 04-29-2008 09:41 AM
differential fluid draxxuspainter8 ZJ Grand Cherokee Forum 4 10-20-2006 08:41 PM
