How do I change serpentine belt in my 5.2 v8? - JeepForum.com
post #1 of 8 Old 04-14-2007, 02:27 PM Thread Starter
rjbasile
How do I change the belt on my 97 grand with the 5.2 V8? Do I just losen the nut on the pully? Will this make the belt slip right off? Do I need to torque it back to a particular spec or just make it tight. I was told this has an automatic tightener. Anyone who has done this, feel free to give me recommondations. Thanks!
rjbasile is offline
post #2 of 8 Old 04-14-2007, 02:40 PM
driabyor
driabyor's Avatar
1994 ZJ
the tensioner rotates clockwise, use a wrench to move it, remove the belt when you relieve the tension. then reverse the order to install
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 8 Old 04-14-2007, 03:25 PM
MotoX5874
yes. the belt has a self adjuster so once the car starts running it should correct itself if you are off a little
Brian
// 5.2 // 4.5" iro // 33" baja claws
MotoX5874 is offline
post #4 of 8 Old 04-14-2007, 03:48 PM
WesTexZJ
Facing the motor the tension pully will be on your left, just below and to the left of the Alternator. You will need a 15mm socket, preferable a 1/2 inch drive. As moto said your rotate the pully clockwise and the belt will be loose. placing the new one on is simple.
good luck
WesTexZJ is offline
post #5 of 8 Old 04-14-2007, 03:54 PM
offhand_remark
offhand_remark's Avatar
1994 ZJ
and if you have an older one that doesn't have the little diagram of how the belt goes around the pullys, make sure you draw one!
1994 ZJ Limited 5.2l V8
"He who fights with monsters should look to it that he himself does not become a monster...When you gaze long into the abyss, the abyss gazes long into you." - Friedriche Nietzche
*________
/l[ ][ ],[___\,_
l-------L –0IIIII0-
()_)--()_)--o-)_)
offhand_remark is offline
post #6 of 8 Old 04-15-2007, 07:48 PM
chiadrum
I had to remove my battery to get enough leverage to extend the tensioner 100%
Before that.I couldn't get the belt on.
After that,it took me like 30 seconds.
chiadrum is offline
post #7 of 8 Old 04-15-2007, 07:49 PM
MotoX5874
It's a wise idea to remove your battery anyway when working with electrical components on your vehicle.
Brian
post #8 of 8 Old 06-29-2013, 01:09 PM
webhostingdesig
So this is really easy? Are there any videos of this? All I could find was a V6 video and a video for a V8 on how to replace the tensioner not just replace the belt, so it was more involved.
webhostingdesig is offline
How do I get my serpentine belt off? 4.0L 02Lightning ZJ Grand Cherokee Forum 20 05-10-2016 09:41 PM
01 WJ Serpentine Belt (4.0) Ford_Prefect ZJ Grand Cherokee Forum 7 07-31-2009 12:21 PM
Serpentine Belt Bricolage ZJ Grand Cherokee Forum 1 04-13-2008 04:24 PM
5.9 serpentine belt... help! aletheuontes ZJ Grand Cherokee Forum 2 12-27-2007 11:27 PM
serpentine belt chadburgwald ZJ Grand Cherokee Forum 1 08-23-2006 06:34 AM
