-   -   How do I change serpentine belt in my 5.2 v8? (http://www.jeepforum.com/forum/f13/how-do-i-change-serpentine-belt-my-5-2-v8-402057/)
rjbasile 04-14-2007 02:27 PM
How do I change the belt on my 97 grand with the 5.2 V8? Do I just losen the nut on the pully? Will this make the belt slip right off? Do I need to torque it back to a particular spec or just make it tight. I was told this has an automatic tightener. Anyone who has done this, feel free to give me recommondations. Thanks!
driabyor 04-14-2007 02:40 PM
the tensioner rotates clockwise, use a wrench to move it, remove the belt when you relieve the tension. then reverse the order to install
MotoX5874 04-14-2007 03:25 PM
yes. the belt has a self adjuster so once the car starts running it should correct itself if you are off a little
WesTexZJ 04-14-2007 03:48 PM
Facing the motor the tension pully will be on your left, just below and to the left of the Alternator. You will need a 15mm socket, preferable a 1/2 inch drive. As moto said your rotate the pully clockwise and the belt will be loose. placing the new one on is simple.
good luck
offhand_remark 04-14-2007 03:54 PM
and if you have an older one that doesn't have the little diagram of how the belt goes around the pullys, make sure you draw one!
chiadrum 04-15-2007 07:48 PM
I had to remove my battery to get enough leverage to extend the tensioner 100%
Before that.I couldn't get the belt on.
After that,it took me like 30 seconds.
MotoX5874 04-15-2007 07:49 PM
It's a wise idea to remove your battery anyway when working with electrical components on your vehicle.
webhostingdesig 06-29-2013 01:09 PM
So this is really easy? Are there any videos of this? All I could find was a V6 video and a video for a V8 on how to replace the tensioner not just replace the belt, so it was more involved.
The time now is 02:17 AM.
