how do i bleed my zj breaks ABS? - JeepForum.com
post #1 of 8 Old 06-18-2011, 02:35 PM Thread Starter
dlvsdh
i just finished my 14 bolt swap and im trying to bleed my breaks. i did a disk swap ive flushed the whole system through till i got clean fluid and no air bubbles but i can still push the pedal to the floor could my abs pump have somthing to do with this since i dont have abs any help i would love
95, ZJ, ORVIS, 1 tons, 37's etc.
2002, WJ, overland, daily driver
dlvsdh is offline
post #2 of 8 Old 06-18-2011, 03:00 PM
Technohead
Get rid of your ABS pump. Check the very end of my build thread to see what I did.
-Eric
Technohead is offline
post #3 of 8 Old 06-18-2011, 03:39 PM
MeanGreenZJ
You need a Thexton 133 Teves IV ABS Brake Bleeder
MeanGreenZJ is offline
post #4 of 8 Old 06-18-2011, 03:53 PM Thread Starter
dlvsdh
why didnt you just use the old zj lines that were originaly there and re bend the to the prop valve. could you give a little more detail on the prosses thanks
dlvsdh is offline
post #5 of 8 Old 06-18-2011, 06:56 PM
Technohead
Because:
1.) I don't do hack jobs and
2.) Like I said in the thread, the original lines were corroded and I've already had two brake line blow outs.
-Eric
post #6 of 8 Old 06-18-2011, 07:03 PM Thread Starter
dlvsdh
Because:
thats right i remember reading that. can you explain your prop valve a little more thanks i dont want to screw this up. witch valve do you recomend
dlvsdh is offline
post #7 of 8 Old 06-19-2011, 04:05 AM
Technohead
The proportioning valve is adjustable. Lifting a vehicle will change the ideal front/rear proportioning. With adjustable valve you can tune the braking to your vehicle.
This is not a difficult job.
-Eric
post #8 of 8 Old 06-19-2011, 11:29 AM Thread Starter
dlvsdh
okay i think ill start on this tommarrow thanks
dlvsdh is offline
New Breaks WKHusker WK Grand Cherokee & XK Commander Forum 6 12-19-2010 08:45 PM
HELP with breaks WJ boyle ZJ Grand Cherokee Forum 5 09-27-2008 09:53 PM
Up Graded breaks? djd24 ZJ Grand Cherokee Forum 9 01-02-2007 12:37 AM
Breaks squeak duckys ZJ Grand Cherokee Forum 4 08-18-2006 02:41 PM
bad breaks freddy45 ZJ Grand Cherokee Forum 2 04-12-2006 05:25 AM
