How to disable DRL on 96 ZJ ??? - JeepForum.com
post #1 of 11 Old 03-23-2008, 01:36 PM Thread Starter
Murdered96grand
ALright... so I bought an HID kit and want to put it on. I know that I need to disable my daytime running lights.
Apparently on a TJ there is a module on the firewall that you can disconnect and bang problem solved. Does anyone know if this particular module exists on a ZJ and if so where is it located. I have been reading posts all morning and digging through wiring diagrams without much luck. I have tried covering the auto sensor with tape. Leaving the park brake on. None of these have allowed the ballasts to fire up. Any suggestions?
Murdered96grand is offline
post #2 of 11 Old 03-23-2008, 06:34 PM
colinzj
2006 WK
Don't have a 96 manual handy, but in the earlier years the DRL module is bolted to the right fender, under the PDC.
Also, please make sure you change your reflectors out if you haven't already.
colinzj is online now
post #3 of 11 Old 03-23-2008, 06:40 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i have 100% percent control of lights on my 98ZJ,
why dose he have to change out the reflectors?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #4 of 11 Old 03-23-2008, 07:04 PM
impuresoul2k3
Because otherwise it will create an awful glare
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #5 of 11 Old 03-23-2008, 07:50 PM
nashmd454
nashmd454's Avatar
my 96 doesn't have day time running lights...I can turn them on and off...as for reflectors...normal headlamps will blind others so you will have to turn them down really low...too low for even you to see.....best advice is getting the clear ones like in my sig...you can find entire lamps (turns and corners as well) as a package for just @ $150. Then you will be fine with no glare and maximize your own output.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #6 of 11 Old 03-23-2008, 07:53 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ok, thanks for being nice about my lack of knowledge of HIDs.
build thread:
5.9 ANDY is offline
post #7 of 11 Old 03-23-2008, 09:07 PM
impuresoul2k3
hey no problem, not many people know and end up doing it anyway, pissing off a lot of drivers.
Air hat spacer
Flowmaster muffler
post #8 of 11 Old 03-24-2008, 11:14 AM Thread Starter
Murdered96grand
I found the module but simply removing it did nothing.
Do the US ZJ's have a different module. If so anybody know what part number it is. The ballast and the lights work fine when I alligator clip twelve volts to them. When the motor is running I have 13.25 volts at the stock connector. If I then connect it to the new HID harness running into the ballast the lights dont activate. This is really wierd. Im thinking that maybe the connectors on the HID kit arent getting a good connection because there doesn't seem to be any other reason.
post #9 of 11 Old 03-24-2008, 01:18 PM
JG_Canuck
I was under the impression the DRL are programmed in the BCM. My Jeep came to Canada from the US, and the PO told me the DRL's were enabled at a Chrysler dealer in Canada.
Of course this is on a WJ. ZJ may be different.
JG_Canuck is offline
post #10 of 11 Old 03-24-2008, 01:38 PM
nashmd454
nashmd454's Avatar
I really wish I could help you...mine was built in Canada (from my build sheet) and I do not have drl's. Cool to have a block heater...even though I never use it.
post #11 of 11 Old 03-24-2008, 01:48 PM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
On my 94, the DRL are manual. You flip the switch from OFF to the left puts it on AUTO. If you go RIGHT from the OFF position, you have PARKING -> HEADLIGHTS -> HEADLIGHTS and FOGs.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
How To : Disable your alarm on your ZJ CLNinja ZJ Grand Cherokee Forum 227 08-06-2016 01:13 PM
how do i disable ABS? ronsaun ZJ Grand Cherokee Forum 54 02-20-2016 01:09 PM
how to disable abs 2blu2 ZJ Grand Cherokee Forum 12 08-25-2009 10:52 AM
How to Disable ABS 98 ZJ? psychade ZJ Grand Cherokee Forum 12 06-20-2008 01:45 PM
Disable start jjag721 ZJ Grand Cherokee Forum 1 03-17-2006 10:03 AM
