How to Disable ABS 98 ZJ? - JeepForum.com
post #1 of 13 Old 06-20-2008, 04:25 AM Thread Starter
psychade
So a friend helped me change my front axle u-joint last night. Slight complication when getting it to pop out.
We dented the round ridged section the abs uses to track itself apparently, when trying to bend the dent out a piece of it snapped off (Forgive me for not knowing what exactly the part is called I think I have heard it referred to as a tone ring? I am not exactly a mechanical mastermind obviously ).
Now when I start the Jeep every time I hit the brakes for about the first 20 seconds the ABS is kicking in and constantly pulsating when trying to brake. This can make getting out of the driveway without driving straight into oncoming traffic a bit dangerous.
The ABS fails and turns itself off shortly there after, but it still takes a bit for it to do so every time I start the Jeep up.
Long story short, I can't really afford to replace it right now, and Id much rather just disable ABS all together until I can. Is there a simple relay I can pull? I don't care about the light being on, I just would like to not slowly creep into oncoming traffic .
As well as any idea of what part I'll need to buy down the line later to fix it. Do I have to buy the entire axle shaft?
psychade is offline
post #2 of 13 Old 06-20-2008, 04:47 AM
ntaousakis
pull out the fuse
IM SOO BROKE WITH THIS JEEP
ntaousakis is offline
post #3 of 13 Old 06-20-2008, 04:57 AM Thread Starter
psychade
Originally Posted by ntaousakis View Post
pull out the fuse
Would the fuse specifically just be for the ABS, or would I end up taking something else out as well? Would it just be listed in my owners manual? Sorry I'm not exactly the sharpest tool in the shed when it comes to these things.
psychade is offline
post #4 of 13 Old 06-20-2008, 05:13 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It is just for the ABS. IF you are unsure, go buy a Haynes or Chilton's repair manual at any autoparts store.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 13 Old 06-20-2008, 06:33 AM Thread Starter
psychade
Hunter
Thanks, I am pretty sure I have one actually in the jeep. I'll give that a shot on lunch.
Any idea what I will have to replace to fix the problem overall? I'm sure I can't just buy the part that broke, as I remember it was rather attached to everything else, will I need an entire axle shaft?
psychade is offline
post #6 of 13 Old 06-20-2008, 06:50 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Just remove a sensor from the front wheels. Its only 1 bolt then zip tie it up. I think if 1 sensor is bad there is no ABS. But you will have the ABS light on the dash.
Are you talking about the ring on the axle shaft? Someone here did replace that ring (I forgot who). If the shaft is bad you can get a new one with the ABS ring on it for about $60 I think. Not too hard of a job if you can turn wrenches.
EDIT
Check this thread out
http://www.jeepforum.com/forum/showt...light=abs+ring
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #7 of 13 Old 06-20-2008, 07:12 AM Thread Starter
psychade
EDIT
Yes I believe that is what I'm talking about. It was on the spindle yoke side of the joint if I remember right. It looks almost like a gear in a way.
Its something like:
Managed to take the entire thing out to do the u-joint, so I figure I could replace it. Hopefully not breaking other things in the process this time.
Edit:Just noticed the thread link, thats pretty much exactly what I did Thanks for the link, I'll think about how I want to tackle it now.
psychade is offline
post #8 of 13 Old 06-20-2008, 07:46 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Well that thread I posted tells how to remove and install one.
Jeep Sold! 02/2009
Need AMSOIL?
post #9 of 13 Old 06-20-2008, 07:49 AM Thread Starter
psychade
I see that, I'm just going to have to see how much one is new from that company, going to call them in a bit. Or if I'd be better off just checking a junkyard. As soon as a get a few minutes I'm going to give them a call. In the interim while I wait for the part I think I'll try just pulling the fuse.
I appreciate you finding that for me
Edit: Yeah that company sold out their stock of those with no intent to bring them back. He also said even if he had it, he has a $25 minimum and 12.50 shipping.
psychade is offline
post #10 of 13 Old 06-20-2008, 07:59 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Cool, yeah check out a junkyard im sure you can get the axle shaft for cheap.
Jeep Sold! 02/2009
Need AMSOIL?
post #11 of 13 Old 06-20-2008, 08:06 AM Thread Starter
psychade
Apparently this is a rather common problem occurence. I called http://www.dearbornaxle.com/ which is a place by me. I asked him for the ring, he asked me if i broke it when changing my u-joint and chuckled a bit. He said he didn't but if I wanted the entire new axle he has a truck full of them. $100 Shipped
psychade is offline
post #12 of 13 Old 06-20-2008, 08:15 AM
crazydude2500
i got a new axel for about 40 but i knew the guy at the parts store that always helps the new axel is about 60 70 ish depending just go to the parts store and get one....junkyard one could be on the way out i dont have abs in my jeep dunno why it comes on and off sometimes haha who knows.....i have cv shafts tho....
crazydude2500 is offline
post #13 of 13 Old 06-20-2008, 01:45 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Sorry, I only had one ring, & NYC ZJ has it now, but maybe someone else can help you. It's rather easy to fix once the axle is out.
http://www.jeepforum.com/forum/f13/can-t-find-right-axle-557124/
This place may sell them:
http://www.rockfordcv.com/PDF%20Downloads/ABS_Rings.PDF
EDIT:I had some free time, so I called the above place, & they no longer sell them. They recommended:
http://www.interparts.com/pdf/ABSRing.pdf
Again, see if you can contact someone here that may have an old axle laying around. '93-98 ZJ (ujoint or CV) are the same... and probably other, too. Mine was a 719-19 54 tooth
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
How To : Disable your alarm on your ZJ CLNinja ZJ Grand Cherokee Forum 227 08-06-2016 01:13 PM
how do i disable ABS? ronsaun ZJ Grand Cherokee Forum 54 02-20-2016 01:09 PM
how to disable abs 2blu2 ZJ Grand Cherokee Forum 12 08-25-2009 10:52 AM
How to disable DRL on 96 ZJ ??? Murdered96grand ZJ Grand Cherokee Forum 10 03-24-2008 01:48 PM
Disable start jjag721 ZJ Grand Cherokee Forum 1 03-17-2006 10:03 AM
