How are cooling systems flushed at dealerships? - JeepForum.com
post #1 of 8 Old 03-20-2005, 07:23 PM Thread Starter
ChesterWilliams
I was going to take in my anti-freeze. Am I wasting my time? They said they have big drums of anti-freeze. Do they flush with water like I would at home? Am I wasting my time taking in anti-freeze or could they use the anti-freeze I take in?
ChesterWilliams is offline
post #2 of 8 Old 03-20-2005, 07:31 PM
greasefingers
greasefingers's Avatar
1994 ZJ
No idea how they do it because I aviod them as much as possible, plus I cannot watch them. Go to the autoparts store and but a flushing tee-kit along with a new heater hose (that you will cut to place the tee in) and buy some DI water at the grocery store. You flush it yourself with a garden hose and the engine running.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 8 Old 03-20-2005, 07:40 PM Thread Starter
ChesterWilliams
Thanks!
I kind of need to take it in because they said they could run a free cooling system check on it. I don't know what is wrong and it could be more than just the anti-freeze needs changed or the thermostat. It is weird because everything runs like normal, it it just that everything is running 20 degrees warmer than usual.
Is it possible that anti-freeze can lose the ability to shed heat to the point of a 20 degrees increase in temperature on the gauge? The gauge reads about 220 when cruising around town at 30 mph or so and gets almost up to 235 mph when pushing 75 mph on interstate. I believe the engine used to read 210 degrees about all the time when I first had it. I haven't had it very long, so I don't really know. All I know is the temperature has slowly gone higher. I have no idea when the anti-freeze was last changed, so I am hoping the anti-freeze or the thermostat is the problem. The vehicle has about 70,000 miles on it.
post #4 of 8 Old 03-21-2005, 06:03 AM
greasefingers
1994 ZJ
There are several things that will reduce cooling:
1- Loose belt
2- Water pump impellers degrading or partly missing
3- Bad thermostat
4- The wrong concentration of anti-freeze. Too much glycol will reduce that cooling.
5- Partially clogged radiator.
6- Clogged catalytic converter (this will also reduce rpms and fuel mileage)
7- Excessive carbon build-up in the cylinders and head
I am sure other can think of some more issues that would cause an engine to run hotter than normal.
Cheers Steve
post #5 of 8 Old 03-21-2005, 11:45 AM Thread Starter
ChesterWilliams
Coolant flush and new thermostat fixed it!
It runs under 210 now!
post #6 of 8 Old 03-21-2005, 07:13 PM Thread Starter
ChesterWilliams
I'd also like to add that the oil pressure increased after the temperaure problem was corrected. The oil pressure would be around 20 psi at idle when the engine was running hotter than it should have been. Now that the engine always stays just below 210 degrees, the idle psi is at 30. This is with synthetic oil. The hotter running engine must have really thinned out the oil.
post #7 of 8 Old 03-22-2005, 06:00 AM
greasefingers
1994 ZJ
Glad to hear that it was a cheap fix
Cheers Steve
post #8 of 8 Old 03-22-2005, 06:58 AM
PDshooter
My I-6 runs right at 210....... But the "Rad," is showing it's age. Will replace it with a "Modine" this summer.
96 GC 117K 4.0
Sele-Trac
Retired guard 20yrs
MOS 63H 11B 43E
PDshooter is offline
Dealerships?-ZJ fuel tank sending unit recall info Shelbyzz ZJ Grand Cherokee Forum 22 09-19-2008 11:07 PM
few questions. calling knowledge on magnet mount cb's, cooling systems, windows, ect fivespeedsteed ZJ Grand Cherokee Forum 19 04-15-2008 09:10 AM
Flushed my coolant and changed my t-stat today. nitrox28 ZJ Grand Cherokee Forum 15 05-05-2007 06:56 PM
Flushed the Heater core and... Yardman Harry ZJ Grand Cherokee Forum 6 12-16-2005 07:55 PM
Flushed Cooling System- No Heat?? Myrtle Beach ZJ Grand Cherokee Forum 9 04-16-2005 02:56 PM
