How to clean your idle air control valve - Page 6 - JeepForum.com
 1Likes
post #76 of 165 Old 07-28-2011, 09:22 AM
jeepzjgrrl
Were the bolts on the back screws or hex? also When i pull the lever towards me the wire doesnt release...it stays. what problems can this cause the jeep when in start up and driving?
jeepzjgrrl is offline
post #77 of 165 Old 07-28-2011, 04:05 PM
Dodgeram1989
1976 FSJ Cherokee
Iirc the bolts are torx20
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #78 of 165 Old 07-28-2011, 07:09 PM
sabzz
What all fluids can you use to clean the IAC? Carb cleaner, brake cleaner etc? Thinking bout doing this to mine just for heck of it. Also, what do you not want to move on it? the part that your cleaning (the dirty part) or what? I got no knowledge about these things so anything is helpful.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #79 of 165 Old 07-28-2011, 07:15 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Throttle Body or Carburetor cleaner is what you want to use. Check the first post.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #80 of 165 Old 07-29-2011, 09:22 AM
mdominy
Has anyone changed the IAC on an '06 Jeep Grand Cherokee (4.7L)? This one is a little different than the ones that are described in any article I can find... Is it the same procedure to clean?
http://www.rockauto.com/catalog/moreinfo.php?pk=934542
mdominy is offline
post #81 of 165 Old 08-01-2011, 09:22 PM
jeepzjgrrl
Thanks I cleaned it but still having issues with stalling. And when I press the gas the oil pressure goes to 80 the back down when I release it.
Sent from my T-Mobile G2 using JeepForum
post #82 of 165 Old 08-02-2011, 05:32 AM
ChuckB
Did mine this morning...had to take TB out to get to the lower screw. Saw how dirty that was and cleaned that up too. Idles much better now
3 WJ's, 1 WK II, 1 JK, 1 JKU, 1 TJ, 1 YJ
ChuckB is offline
post #83 of 165 Old 08-02-2011, 10:10 AM
VinnieTheFish
2014 WK
Cleaned mine out this weekend after seafoaming the engine, doing a compression test, changed spark plugs/wires/rotor/cap and checked the engine vaccum. Even after the tune up before cleaning the TB and IAC the Jeep was running a bit rough, but after following the instructions from the first post it's purring like a kitten.
Big thank you for the write up! JeepForum.com rocks!
VinnieTheFish is offline
post #84 of 165 Old 08-12-2011, 02:44 AM
Jeepman82
I'm trying to do some research for you on this one, bc I dont know how you'd clean this one compaired to mine.
I also have a question for someone to answer...even though I cleaned mine up and it took care of the problem of low idle and stall outs, I noticed that the electrical connector was unplugged from the IAC. It has a small diode plugged into it as if completing the circut. It was wrapped with electrical tape. Like I said in a previous post, the previous owner took many, many shortcuts and rigged all kinds of crazy things with my Jeep and in the 3 years that I've owned it, I've been coming along things and fixing them the correct way. Should I correct this problem as well and pull the diode out and plug the connector back into the IAC? Now I'm wondering if the IAC pintle/plunger motor even works and is the reason why the previous owner took the shortcut?
ºlllllllº •JEEPMAN82• ºlllllllº
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
Jeepman82 is offline
post #85 of 165 Old 08-27-2011, 03:09 PM
GSUDave
Nice write up on cleaning the IAC. I have a 2001 4.7 WJ w/ 177k. Yesterday I removed the throttle body, cleaned it, replaced the TPS, and cleaned the IAC like the write up shows. My idle has improved greatly. But my question is why does the IAC have all the carbon build up (I guess this is what it is) on it. Is that normal, or is that coming from another problem?
GSUDave is offline
post #86 of 165 Old 08-27-2011, 05:02 PM
Candymancan
I have a question, would a bad TPS cause rpm surging when the engine is cold ? I noticed recently that my 5.9 when i start it and take off and drive slow outa the neighborhood that the rpm's surge 100 up and down until i get speed and everything is warmed up.
Candymancan is offline
post #87 of 165 Old 09-24-2011, 11:16 AM
dwnorman
1994 ZJ
Thanks, I needed that
I think that this is my answer... too long to write.
dwnorman is offline
post #88 of 165 Old 09-29-2011, 09:08 AM
Nahkohse
Thanks for this... i did this and now my XJ purrrrrrrrrs... messed up the wifes toothbrush though
Nahkohse is offline
post #89 of 165 Old 09-29-2011, 09:27 AM
speedbucket
mine does this if i am rolling and throw it in neutral
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #90 of 165 Old 09-29-2011, 11:40 AM
bigbill888
nahkose, maybe she won't notice.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
Idle Air Control Valve Fun greasefingers ZJ Grand Cherokee Forum 4 08-13-2011 05:01 AM
How hard to clean out idle air control valve on 2006 with 4.7? cariboulou WK Grand Cherokee & XK Commander Forum 3 04-17-2009 04:01 PM
95 Grand Cherokee Stalling...Idle Air Control Valve G4teamG ZJ Grand Cherokee Forum 2 02-18-2009 02:45 PM
idle air control valve 4weeln ZJ Grand Cherokee Forum 2 04-11-2005 01:46 PM
Idle Air Control Valve TSFSU ZJ Grand Cherokee Forum 0 06-28-2004 10:07 PM
