> Models
> Jeep Grand Cherokee & Commander Forums
> ZJ Grand Cherokee Forum
How to clean your idle air control valve
06-16-2009, 08:09 AM
#31
I cleaned mine on Friday, but it didn't help matters any. one thing I did notice.. my 127k mi. '97 5.2L.. if it's idling, and I unplug the IAC, there's "no change" in idle speed. AT ALL..
I'm chasing down a problem of low-to-no idle condition, and stalling when I let off the throttle.. I've already tried the 'screws' method on the ECU, so that doesn't appear to be it, either.
But, good write-up on the IAC cleaning article!
'96 XJ - 8" RC lift - 33x12.50s, IRO long-Arm, Rusty's leafs, Boomerangs, etc.
06-16-2009, 08:20 AM
#32
When I cleaned mine recently I unscrewed the plunger out, disassembled the spring, pin, & plunger, and cleaned that area too. It seems to work OK upon reassembly. That was about a week ago. It idles and runs much better.
How much does an IAC cost to replace it, in case I broke it?
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
06-16-2009, 08:25 AM
#33
if i remember correctly, the IAC can be anywhere from $60-$110. I gotta run to work to pick something up, i'll check for you.
1998 ZJ Laredo, 4.0L, 2WD "Band Van", Current
1997 XJ, 4.0L, 30x9.50 Maxxis Bighorns, super 44, Sold
2003 WJ Overland, 4.7L HO V8, 6000K HID's, Sold
1996 ZJ Laredo, 5.2L V8, 3" Kolak exhaust, K&N FIPK, 4300K HID's, Sold
http://www.facebook.com/home.php#/pr...27&ref=profile
06-16-2009, 08:30 AM
#34
Sounds like your IAC is in fact broken, if nothing changes when you unplug it.
Ryan
'98 ZJ V8 Limited '06 WK V8 Laredo '51 CJ-3A
06-16-2009, 08:31 AM
#35
I got an Airtex IAC from Rockauto for around $35. It broke within a month, but they're sending me a new one free of charge.
Ryan
06-16-2009, 08:38 AM
#36
$30(AirTex) - $50 (ACDelco) on RockAuto (just looked yesterday)
figures..
I'll order one.
Is there any ideas as to the stalling issue that I am experiencing, other than the IAC, PCM 'screw fix' items?
06-16-2009, 08:54 AM
#37
ZJjazzyJim
Added to the FAQ - thanks Haley
Jim Karlin "How the heck do you get there?"
"Duh! Big RED Jeep!!!" Best customer service in the states:
Best mod you'll ever do on ANY vehicle!!!!
06-16-2009, 11:07 AM
#38
Cool! Thanks FPKites. And yes, I checked at work and its $65 from autozone for your XJ twobit.
07-11-2009, 05:25 PM
#39
Hi I'm new to the forum and need your help. I recently purchased a 1999 Wrangler Sahara, with 4.0L and auto transmission - my first Jeep. It has about 82K on it. I installed a Banks cold air intake and Banks cat back exhaust. We took it on it's first long trip this weekend and on four occassions, when we slowed down to stop for a light the engine took off by itself and raced wildly. The first time I almost couldn't hold it with the brakes and nearly hit the guy in front of me. The next three times I slammed it into neutral and it came back down to normal idle after a second or two. Now when I slow down and stop, if I feel the engine starting to race, I put it in neutral and it goes back down to normal idle after a second or two. Could a dirty IAC be causing this? Thanks in advance for any help you can give me.
07-12-2009, 09:02 PM
#40
Yea, didn't know about pushing/pulling on mine. But seems okay still. Cleaned it pretty good and didnt seem better or worse. Few days later I revved it up in park and the idle doesnt drop down to under 500 now, so guess it worked.
Tip on removing the screws: I use this with the "star" bit and soooo easy to get to, plus magnetic so no accidental bits fall into motor.
best_iac_tool_ever
07-12-2009, 10:50 PM
#41
I dont think its IAC, sounds like TPS (throttle position sensor) to me. My boyfriend has a TJ, and his check engine light came on, and the rpms would go up and down slightly at idle. He replaced it and it did fine for about a month, and tonight as he was driving on the freeway home his CEL came back on and started reving and dropping, which sounds similar to your problem. Do you have a check engine light on?
01-21-2010, 12:14 AM
#42
where is this Idle air control on 98 jeep grand che I6 ?
01-21-2010, 12:15 PM
#43
should be the same location on my xj....so back side of the throttle body on the left (sensor closest to valve cover on the back side of the TB)
03-11-2010, 05:54 PM
#44
i just cleaned mine and it doesn't seem like it helped at all. i think i may have broken it. what do your rpms usually run at? mine is hovering just below the second dot. also, by cleaning the IAC do you see instant results or do you have to drive it a little bit?
03-11-2010, 11:58 PM
#45
You should idle pretty dead on at 700rpm. You should see instant results, did you disconnected you battery before cleaning?
