How to clean your idle air control valve - Page 2 - JeepForum.com
 1Likes
post #16 of 165 Old 04-21-2009, 10:18 PM Thread Starter
Haleyrz
Originally Posted by five.nein View Post
You should clean the hole in TB too. Where the plunger mates.
I did do that, and cleaned the throttle body while i was there. So to add to the writeup:
Make sure to clean out the hole the IAC goes into.
thanks for clearing up the WOman part, lol. And its relatively the same place on the I6, but a PITA to get off! The bottom bolt has a bunch of crap in front of it that makes it really really hard to get to. At least its that way on my boyfriends TJ. I went to clean his and our small collection of tools cant get to it.
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #17 of 165 Old 04-21-2009, 10:29 PM
JasonJ1969
On the I6 it's easier to just take the whole throttle body off after disconnecting the wires and cables. Then you can pop the IAC off with ease and clean the whole mess. I just did this on the 02 WJ yesterday, it had the high idle on start-up thing going. It also had an awesome oil leak dripping oil on the exhaust pipe. Found loose bolts on the valve cover and oil pan. Don't know which caused the leak, but after tightening it all up the leak is gone. I have fixed more stuff on that 02 in the last week than I ever have on my 95 Ford F150, and I have had that truck longer than my 02 has been alive....
JasonJ1969 is offline
post #18 of 165 Old 04-28-2009, 04:32 PM
ey1979
i did the cleaning but the silver part on IAC that u have on it was yellow or gold color on mine. is it different?
1993 Jeep Grand Wagoneer V8 5.2L 136.431 miles
ey1979 is offline
post #19 of 165 Old 04-29-2009, 12:18 AM Thread Starter
Haleyrz
it may have been replaced at some point, or being that yours is older it might just be a different part, yes.
Haleyrz is offline
post #20 of 165 Old 04-29-2009, 09:34 AM
crashcraddock
Would this apply to a 4.7 WJ? Mine starts up to 2600rpms and takes a little while to idle down. With the flo though it scares people on start up.lol
crashcraddock is offline
post #21 of 165 Old 04-29-2009, 11:48 AM Thread Starter
Haleyrz
yeah it should, i'm just not sure where exactly it is on the WJ...i've never looked at a 4.7 in person. It will be on the throttle body somewhere. On my 5.2 there are 3 sensors on there. Just google 2000 Grand Cherokee idle air control valve and try to get a part number to google that number so you can look at the shape, or maybe the search will come up with more info and pictures than my search for the 5.2 did.
Haleyrz is offline
post #22 of 165 Old 04-29-2009, 12:12 PM
ISUzj
2005 WK
thanks for the write up, i did this on Sunday...idles so much smoother now, i think i burned my hand getting the thing out though
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #23 of 165 Old 04-29-2009, 04:15 PM
Mickey_D
I just went out and did mine. My IAC wasn't too bad, but my throttle body needs help. Badly. All in below the throttle plates is BLACK!!
By the way, I took my Dremel tool on the lowest speed possible with a brass wire brush in it to my IAC. Worked like a charm. Took all the deposits off in a matter of seconds, but was soft enough not to damage the plunger at all.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #24 of 165 Old 04-29-2009, 04:31 PM
vansskaterfreek
haley, we need pics of you smiling and cleaning it, it will make more people do it, kinda like advertising this should be in the FAQ section, or at least in the sticky's
94laredolover likes this.
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #25 of 165 Old 04-29-2009, 07:26 PM
dobe
Originally Posted by RyanZJ View Post
One thing you might want to mention in your writeup is to make sure not to push or pull on the pintle, and to avoid spinning it. Other than that, nice writeup!
Can you explain to me how you will break it if you push or pull on the pintle ?
dobe is offline
post #26 of 165 Old 04-29-2009, 08:32 PM
vansskaterfreek
i did it, and mine still works.......it took a while to idle down, but still works
post #27 of 165 Old 04-29-2009, 09:35 PM
Virmagicus
Virmagicus's Avatar
Because it is not supposed to me moved without input from the puter. It ****s it up.
Jeff
Virmagicus is offline
post #28 of 165 Old 04-29-2009, 09:37 PM
Mickey_D
If I understand the inner workings correctly, it's a gear driven servo motor that actually moves the plunger. On a worm gear. Like a garage door opener. If you force it, it will strip the drive gear out.
________________
#4
Mickey_D is offline
post #29 of 165 Old 04-29-2009, 11:00 PM
tbm5690
On the 4.7L both the IAC and TPS are located on the right (driver) side of the TB. You will see two wire connectors going into the side of the TB...the one with the white end is the TPS and the other is for the IAC. Simply disconnect the connector and use a torx driver to remove the two screws holding it on. For a more thorough cleaning I would just recommend removing the TB...especially because just getting to the IAC requires removing the resonator box anyways.
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #30 of 165 Old 04-30-2009, 12:54 AM
dobe
I've always repositioned the pintle before reinstalling the IAC.
Done this on many many vehicles with no problems yet.
While pushing on the pintle with my thumb I gently rock it back N forth
till it goes in some.
Just saying it can be done.
I've read articles that actually reccomend it.
dobe is offline
Idle Air Control Valve Fun greasefingers ZJ Grand Cherokee Forum 4 08-13-2011 05:01 AM
How hard to clean out idle air control valve on 2006 with 4.7? cariboulou WK Grand Cherokee & XK Commander Forum 3 04-17-2009 04:01 PM
95 Grand Cherokee Stalling...Idle Air Control Valve G4teamG ZJ Grand Cherokee Forum 2 02-18-2009 02:45 PM
idle air control valve 4weeln ZJ Grand Cherokee Forum 2 04-11-2005 01:46 PM
Idle Air Control Valve TSFSU ZJ Grand Cherokee Forum 0 06-28-2004 10:07 PM
