Quantcast How to clean your idle air control valve - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > How to clean your idle air control valve
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 04-19-2009, 09:14 PM   #1
Haleyrz
1997 XJ Cherokee
I figured I'd write up a how to for anyones future reference in attempt to prevent a ton of posts about this (but we all know how the search feature is not utilized, haha). Anyways, the jeep was idling a little rough and at times it would start up at 2200 rpms and slowly settle down so a few had recommended me to change or clean my IAC (idle air control valve). Figured I would clean it first.
Step one: Buy a throttle body cleaner or carburetor cleaner to clean with. Carb cleaner will be much much stronger so I went with throttle body cleaner. I didn't want to ruin anything.
Step Two: Remove the intake tube and reveal the throttle body.
Step Three: DISCONNECT THE BATTERY!
Step Four: Locate the IAC. In my case with my 5.2L V8 ZJ, its on the back of the throttle body. Remove the two bolts and it will come out.
Step Five: Disconnect the IAC from the power connector. This is how dirty mine was!
Step Six: Spray, wipe, spray wipe til clean. And here it is!
You can from here continue to clean out your throttle body. I would recommend this. My jeep idles like butter now!
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44
2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT
1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT
My build thread
http://www.myspace.com/HaleyChicoine
http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile
Haleyrz is offline   Reply With Quote
Old 04-19-2009, 10:43 PM   #2
micifus
Original GC'er
micifus's Avatar
electric tooth brush, Classy
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 04-19-2009, 10:45 PM   #3
Haleyrz
1997 XJ Cherokee
Its not an electric tooth brush! Its a SonicStage Detail brush! Lol....ok, technically its a tooth brush. I bought it for my wheels, because thats what lazy people do. But i've found some interesting uses around the jeep since, lol.
My build thread
Old 04-20-2009, 02:03 AM   #4
CULate
1930 J-Series Truck
Good write up. Thanks
CULate is offline   Reply With Quote
Old 04-21-2009, 10:03 AM   #5
T Hoff
1975 CJ5
Like Butter
Thank you Linda Richman
Same location on the L6?
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
T Hoff is offline   Reply With Quote
Old 04-21-2009, 10:20 AM   #6
RyanZJ
One thing you might want to mention in your writeup is to make sure not to push or pull on the pintle, and to avoid spinning it. Other than that, nice writeup!
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline   Reply With Quote
Old 04-21-2009, 10:22 AM   #7
T Hoff
1975 CJ5
Doesn't it work like a solenoid? It would move in and out as required. I thought anyway
Old 04-21-2009, 10:44 AM   #8
RyanZJ
Yeah, but if you push/pull on it you'll break it.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
Old 04-21-2009, 10:47 AM   #9
besthaticouldo
1994 ZJ
good write up man...thanks!
3.5 BDS, Rancho 9000xl shocks, 31x10.5x15 BFG A/Ts, KOR lower rad support, JKS quicker discos, Hella 500s, 3" magnaflow exhaust, KOR-alike Roof Rack, IRO tie rod...bunch of other stupid crap.
Greatest Thing You've Ever Seen
besthaticouldo is offline   Reply With Quote
Old 04-21-2009, 11:05 AM   #10
zippome
Originally Posted by besthaticouldo View Post
good write up WOman...thanks!
haha there ya go
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline   Reply With Quote
Old 04-21-2009, 11:08 AM   #11
besthaticouldo
1994 ZJ
Originally Posted by zippome View Post
haha there ya go
thanks! sorry i totally assumed it was a dude, my apologies
Old 04-21-2009, 12:01 PM   #12
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You should clean the hole in TB too. Where the plunger mates.
HighLonesome is offline   Reply With Quote
Old 04-21-2009, 05:54 PM   #13
shdybrady19
hey mine doesnt have a shaft it just has a spring. Is this normal?
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline   Reply With Quote
Old 04-21-2009, 07:13 PM   #14
ZeeJay1997
If I understand your question:
Uhmmmm.... NO!
The plunger is probably still in the hole...
Time for a new IAC
97 ZJ, 4.0, 2WD, 3.73s.
ZeeJay1997 is offline   Reply With Quote
Old 04-21-2009, 07:28 PM   #15
shdybrady19
i replaced it and it works. Still dies in reverse tho.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
