How To: change transmission electronics - Page 2 - JeepForum.com
post #16 of 28 Old 11-09-2013, 09:45 AM Thread Starter
gearheadnick
kahl452: I'm glad this helped you. That's the reason I posted this. It's not that hard, and it'll save a ton of money rather than going to a trans shop.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #17 of 28 Old 11-09-2013, 01:22 PM
kahl452
How much transmission fluid did you put in yours? In the owners manual it says 9.6L but last time I filled it its 7 quarts and it was over max. Since actually fixing it. I only put in 6 quarts. It seems fine.
Search is your best friend.
Helpful links
kahl452 is offline
post #18 of 28 Old 11-09-2013, 04:54 PM Thread Starter
gearheadnick
I think mine took 6 quarts. I took a tip from ericthecarguy (does great youtube vehicle repair videos). I knew that it would take a minimum of 4 quarts, so that's what I put in. When I was able to start it up, with the jeep sitting level, I let it get to operating temp, put it in neutral, put on the parking brake (or chock the wheels), and checked the level. I kept adding and checking until it was full.
There's no way it'll take 9.6 liters, that's over 10 quarts. Maybe if the trans is bone dry, including the torque converter and fluid cooler. But for just a filter change, it's 5 or 6 quarts.
post #19 of 28 Old 11-12-2013, 05:52 PM
Gibby913
Thanks for the input gear I'll make sure to let you know how it turns out when I do it in the spring
-=Gibby=-
1997 Jeep Grand Cherokee 4.0L I-6 150,600
Gibby913 is offline
post #20 of 28 Old 12-30-2014, 02:03 PM
Gibby913
As an update I did this and everything went well. She seems to be downshifting normally again. I forgot to replace the output speed sensore unit, the one with the 1" socket. Can I do this after I put fluid back in or is it gonna pour out of there like a siv????
-=Gibby=-
Gibby913 is offline
post #21 of 28 Old 12-30-2014, 02:26 PM
JaimeZX
I was also very pleased with this kit. Worked great for me.
@Gibby - that's a very easy swap. Expect a few tablespoons of fluid; not too bad.
HID Projector retro! http://www.jeepforum.com/forum/f13/hid-projector-retrofit-build-thread-3082289/
JaimeZX is offline
post #22 of 28 Old 09-13-2015, 01:14 PM
meximan
Just did this over the weekend however my kit didnt have a piston thing with the new heavy duty spring? What was the piston for ?
meximan is offline
post #23 of 28 Old 09-13-2015, 03:51 PM
JaimeZX
The piston is part of the transmission. You just swap out the spring.
JaimeZX is offline
post #24 of 28 Old 09-13-2015, 05:03 PM
meximan
oh ok i wasnt sure if it was supposed to go in the valve body or something. I thought maybe i was missing some parts lol
meximan is offline
post #25 of 28 Old 09-13-2015, 06:09 PM
JaimeZX
No. Did you watch Cascade's Youtube video?
JaimeZX is offline
post #26 of 28 Old 09-13-2015, 10:54 PM
meximan
yes ! but i didnt remember seing that part!
meximan is offline
post #27 of 28 Old 02-28-2017, 04:37 AM
mota32gd1767
This was a very good write it allowed me to complete this project with minimal problems. however it didn't fix my problem of starting off in second gear. one of the problems I'm sure was the non metallic metal shavings that were lining the bottom of my drain pan. Thank goodness I have some really good Jeep buddies and one of them is selling me a 44re trans for $150. o ne good thing, this next trans will have all new electronics
mota32gd1767 is offline
post #28 of 28 Old 03-03-2017, 06:10 AM
jeepjeepster
Probably torque converter fin shavings...
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
