How can i test sensors? - JeepForum.com
post #1 of 8 Old 08-12-2017, 01:36 PM Thread Starter
leone1907
how can i test map sensor,TPS,CPS,ACTP
Which causes excessive fuel consumption?
leone1907 is offline
post #2 of 8 Old 08-12-2017, 06:15 PM
clrkent67
I had all indications of a bad o2 on my 98 and found a vacuum leak to be the culprit
Sent from my SM-G930P using Tapatalk
clrkent67 is offline
post #3 of 8 Old 08-13-2017, 12:43 PM
mikem350
1994 ZJ
Have heard this before...easiest way to check things is to let the Jeep's computer tell you any problems. That is hook up a OBDII scanner if its a 96 or newer.....
agree about vacuum leaks too
Proud owner of two ZJs
Red 94 mint!
Silver 98 just hit 300k miles....runs like new!
mikem350 is offline
post #4 of 8 Old 08-13-2017, 01:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
Would help if you told us engine and year.
I would like to know what an ACTP sensor is.
kg6mov is offline
post #5 of 8 Old 08-13-2017, 01:43 PM Thread Starter
leone1907
1995 zj 5,2
my computer not working, obd scanner not show any problem but my car Fuel consumption is too high; 35lt / 100km.
(Air Charge Temperature Sensor)
post #6 of 8 Old 08-13-2017, 01:55 PM
kg6mov
Hears the voices
kg6mov's Avatar
O2 is most likely if you are not experiencing a stalling issue.
How much oil is in the intake?
kg6mov is offline
post #7 of 8 Old 08-15-2017, 04:32 PM
AVR2
Originally Posted by leone1907 View Post
1995 zj 5,2
93-95 ZJs are OBD1, and so you only get a small number of fault codes. Many scanners cannot read OBD1 anyway because it wasn't a true standard the way OBD2 is. Every manufacturer basically did their own thing with OBD1, which is why few generic scanners support it and you usually have to get the specific OBD1 factory scan tool for your vehicle to do anything useful.
What you really need is the 5.2L powertrain diagnostic manual for 1995 (it's something very different to the FSM and goes into serious detail about the engine sensors), but I can't seem to see one on eBay for your year. There's one for 1997 (which is an OBD2 year and so may have differences in sensor voltages etc). Loads of the 4.0L powertrain diagnostic manual for 93-95 though.
AVR2 is offline
post #8 of 8 Old 08-19-2017, 12:03 AM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Every sensor has a specific testing procedure, which is not always 100% reliable. Some are based on voltage readings, some on resistance readings, etc. In all cases, what you are testing is the sensor proper calibration. But very importantly, you want to narrow down your search to those sensors affecting air/fuel mixture specifically. For instance, TPS and CPS will have little to no effect, and rather a big effect on engine's ability to run at all.
You probably want to look first at your upstream O2 sensor(s) and coolant temp sensor. The CTS in fact determines open/close loop operations. A bad CTS can sometimes be overlooked even though it can delay closed loop operations because the computer thinks it hasn't reached operating temp yet, which means your engine burns more fuel than is needed instead of relying on O2 sensor's readings.
Bad sensors won't necessarily throw an engine code and I would NOT wait for on an engine code to establish a sensor is bad. In order to throw a code, the readings have to be significantly outside pre-determined values, which your computer may not always detect and are set arbitrarily anyway.
If you decide to change a sensor, I strongly recommend to go OEM. Aftermarket sensors are not set to OEM calibration and could in fact make the problem worse. A perfect example would be Bosh O2 sensors on Chrysler vehicles. Bad combination.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
fuel economy , grand cherokee , MAP sensor , tps
