How can I improve the gas milage on my 97 ZJ?? - JeepForum.com
post #1 of 25 Old 03-04-2010, 08:55 PM Thread Starter
ufc925
So I know that I may sound like a noob asking this question, but I just don't know who else to ask. What can I do to my 97 ZJ to improve gas milage? I heard a cold air intake would improve but its like $500+, and im not sure it would make a huge difference. I'm getting like 230 miles on a full tank, or almost 13MPG.. My wallet is starting to feel the pain.
Anyways, I'm open to all suggestions. Thanks!
ufc925 is offline
post #2 of 25 Old 03-04-2010, 09:20 PM
Az-Green
1994 ZJ
Get literally any other vehicle on the planet. Jeep's have the aerodynamics of a brick and the 5.2L doesn't help you any.
Az-Green is offline
post #3 of 25 Old 03-04-2010, 09:58 PM
lateralus3
1994 ZJ
give it a good tune up. plugs, rotor, wires, oil, oil filter, fuel filter, air filter. when i first bought my zj i was wondering why it wasnt getting very good gas milage, well i poped open the intake box and i had a squirrels nest in my intake. cleaned it out and put a new filter in and was much better lol
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #4 of 25 Old 03-04-2010, 10:13 PM
rm2001wj
rm2001wj's Avatar
A cold air intake might give a little more power at higher rpms when at wide open throttle, but it can't improve mpgs. Do the tune up and consider replacing the upstream O2 sensor.
rm2001wj is offline
post #5 of 25 Old 03-04-2010, 10:22 PM
jeremy8302
The simple answer is to drive slower. I stick to 65 mph on the freeway and try to keep it under 2000 rpm as much as possible. I get 18.5-19 mpg and I catch up with the people that race past me in most cases.
1998 ZJ Laredo SE 2WD, 4.0L I6, 142,000 miles, 42re (re-built), clear headlight housings, 9007 conversion, clear corners, K&N drop-in filter, 70 series flowmaster
jeremy8302 is offline
post #6 of 25 Old 03-04-2010, 10:50 PM
4Slow9erHybrid
What's the ethanol content of the gas you are using? I saw a consistent 20% drop in mpg when Shell introduced the 10% ethanol in their regular gas. So now I bought Costco gas (no ethanol is indicated at the pump), and it seems my mpg is back to normal. Need to drive a bit longer to be sure. In city traffic you won't get more than 15mpg, except if your "city" has only one intersection. You'll see sometimes people on here claiming 18mpg "city".
On the highway keep your speed below 65mph, makes a huge difference.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #7 of 25 Old 03-05-2010, 05:30 AM
Technohead
Aside from a basic tune-up there is nothing you can do that will recoup your investment. If gas mileage is an issue then you are driving the wrong kind of vehicle.
-Eric
Technohead is offline
post #8 of 25 Old 03-05-2010, 10:18 AM Thread Starter
ufc925
Its been tuned up and i just recently took care of all that stuff. Is it true that switching to a premium synthetic oil will help MPGs?
ufc925 is offline
post #9 of 25 Old 03-05-2010, 02:44 PM
4Slow9erHybrid
NO! Don't switch to synthetic in hope of getting better mpg. I have synthetic fluids all around, except the power steering. But it's to reduce wear and to be able to change the fluids less frequently. You might gain a bit of mpg if you live in extremely cold climate and do lots of short trips.
post #10 of 25 Old 03-05-2010, 03:09 PM
melk
New plugs and air filter are your easiest and cheapest options.
Next up, as someone else mentioned, replace your O2 sensors.
melk is offline
post #11 of 25 Old 03-05-2010, 04:21 PM
Dukota
Not true. I bought a $49 cold air intake off of ebay and picked up a couple miles per gallon. I made no other changes.
Whoever dies with the most toys, wins.
Dukota is offline
post #12 of 25 Old 03-05-2010, 04:39 PM
subliminal
1997 XJ Cherokee
Wrong they do increase mpg, I saw a 3 mpg increase when I installed mine and JP magazine also did a review of different intakes and found the average mpg increase was between 3-4 mpg.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #13 of 25 Old 03-05-2010, 04:43 PM
4Slow9erHybrid
post #14 of 25 Old 03-05-2010, 04:48 PM
subliminal
1997 XJ Cherokee
Hey facts are facts I had had one on my trans am and also saw an increase in mpg, Are they the best intake for offroading? Probably not since water could be more easily sucked in and they will get dirty faster than the stock intake. But if youre mostly going to be driving on the street they do make a noticeable difference in mpg.
post #15 of 25 Old 03-05-2010, 05:03 PM
terryj
2015 WK
The fastest way to increase you gas mileage is, believe it or not, change your air filter and your spark plugs.
terryj is offline
improve power 4L stevew_sa ZJ Grand Cherokee Forum 10 10-07-2008 07:25 AM
need to improve gas mileage sjhill81 ZJ Grand Cherokee Forum 9 05-16-2007 10:33 PM
how to improve MPG on 4.7?? daphunkie12 WK Grand Cherokee & XK Commander Forum 3 09-06-2006 12:49 AM
Anyway to improve milage? Zeitgeist ZJ Grand Cherokee Forum 27 08-16-2006 10:07 PM
What can I do to improve Gas mileage Overland2002 ZJ Grand Cherokee Forum 26 10-24-2004 07:54 PM
