How to bypass master lock on windows? - JeepForum.com
post #1 of 4 Old 09-12-2005, 01:34 PM Thread Starter
texasmail1962
I have 1994 Grand Cherokee. The Master lock on the windows is broken. I can operate all the windows from the drivers side. All other window controls will not work. I beleive the master lock switch is broken. Does anybody know how to bypass the switch? Thanks for the help.
texasmail1962 is offline
post #2 of 4 Old 09-12-2005, 08:05 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Its probably a short circuit in the switch or one of the wires to the switch. you will probably have to get a wiring diagram and take the door apart and test the wiring. if its a bad wire it probably can be fixed, if the switch is bad you may have to change out the whole unit.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 4 Old 09-12-2005, 08:16 PM Thread Starter
texasmail1962
I took my door panel off yesterday. There is a lot of wires going to switch. I was hoping somebody here could tell me which wires would bypass the master lock switch.
post #4 of 4 Old 09-12-2005, 08:31 PM
-Joe-
-Joe-'s Avatar
The diagram in my haynes says the grey wire is connected to the master lock switch and goes into a black 16 pin connector. From the diagram if this wire is cut the master lock button is always open.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
Problem with 04 Grand Cherokee Windows, Lock ETC> PoliceDrummer ZJ Grand Cherokee Forum 7 09-22-2009 05:18 AM
~ Power windows and door lock issues ~ SouthSeaPirate ZJ Grand Cherokee Forum 8 08-20-2009 10:27 PM
Power windows/locks/keyless lock doesn't work matt21484 ZJ Grand Cherokee Forum 22 04-21-2009 08:57 AM
Master door lock switch, intermittant response xSnoWx ZJ Grand Cherokee Forum 2 03-22-2009 10:53 AM
Anyone using (Wheel lock) Master Lock Tatinium or Club ??? Webb ZJ Grand Cherokee Forum 5 06-04-2003 08:15 AM
