How big of a difference do gears make? - JeepForum.com
post #1 of 28 Old 07-24-2011, 03:49 PM Thread Starter
Tdaz250
1994 ZJ
Thinking for in the future if I get 32s or 33s how big of a difference do gears make. I have 31s right now with probably 3.55 and it's pretty slugish but not enough to justify dropping 1000 bucks on a vehicle that's only worth 3k if that.
I would basically just like to be able to drive in town and not feel like I'm straining everything when I go from every stop light.
Tia guys. I know there are alot of threads about gears but I haven't really found one that addresses my question.
Also I'm curious what gas mileage is like with 33s and 4.56 gears...I drive about 20 miles round trip per day and it's all in town.
94 ZJ 4.0
3.5 lift with 31 inch Toyo MT's
Tdaz250 is offline
post #2 of 28 Old 07-24-2011, 04:33 PM
blackjack12982
1994 ZJ
Why not get a set of axles out of a V8 ZJ? They're 3.73 geared, and if you get the later 96-98 model axles, you'd have a D44a instead of the D35. That being said, I'm still running 3.73 gears with 35's and my 5.2. I can definitely tell a difference, I can no longer light up the tires like I could on 2" and 31's, but it's definitely still drive it decently.
blackjack12982 is offline
post #3 of 28 Old 07-24-2011, 06:37 PM
biggoofy
My 4.0 on 33s is so slow haha its drivable but not great on hills. if i planned to stay on 33s i would go 4.56 and stay there.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #4 of 28 Old 07-24-2011, 07:19 PM
Technohead
Originally Posted by Tdaz250 View Post
. . . I would basically just like to be able to drive in town . . .
Driving in town? Gas mileage? Sounds like you need a Honda.
-Eric
Technohead is offline
post #5 of 28 Old 07-24-2011, 07:43 PM
jforse
Lol
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #6 of 28 Old 07-24-2011, 08:00 PM
KingtheZJ
x2 on the 96-98 v8 axle swap.
or if you have the money and skill, go for the hp30/8.8 swap with 4.10s and ltd slip in the 8.8. that would be ideal and cheapest thing to get the farthest without having to regear axles.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #7 of 28 Old 07-24-2011, 08:20 PM Thread Starter
Tdaz250
1994 ZJ
Do any 8.8s come with 4.10s stock ?
I know I'm saying gas mileage...but I was saying that in regards to I'm going to want gears with more power since mostly what the jeep does is stop and go when it's not on the trails
94 ZJ 4.0
Tdaz250 is offline
post #8 of 28 Old 07-24-2011, 08:25 PM
blackjack12982
1994 ZJ
Yes, they are.
But 4.10 HP30's are pretty rare in my experience. I tried to find one for quite some time before I just got a 3.55 geared HP30 and regeared it to 3.73.
Last edited by blackjack12982; 07-24-2011 at 08:25 PM. Reason: made it less confusing...
post #9 of 28 Old 07-24-2011, 08:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
3.73's behind the 4.0 with 33's is still going to be sluggish.
4.56 or nothing imo.
ratmonkey is offline
post #10 of 28 Old 07-24-2011, 11:51 PM
lateralus3
1994 ZJ
I know it will make s world of a difference when I go from 3.55s on 35s to 4.56
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #11 of 28 Old 07-25-2011, 05:06 AM
AlphaLorde
But Jeep wins wars, Honda mows lawns
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #12 of 28 Old 07-25-2011, 05:13 AM
AlphaLorde
If ya planning 35s, 4.88s would match up better ratio wise. Even more so important sense you have the 4.slo. If ya had a v8 it would be so bad.
Gear price shouldnt change with the ratio chosen, having that little bit more of power with a little deeper gears it worth it.
Can neva go wrong with More Power.....
post #13 of 28 Old 07-25-2011, 01:14 PM
gothchick
I'm running 4.10 and 33's with a 4.0L. It's equivalent to the factory gear ratio, but I think it'd pull better on the highway with 4.56s. The difference between 4.10 and 4.56 is about 200rpm's.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #14 of 28 Old 07-25-2011, 01:22 PM
KingtheZJ
FWIW, two of the guys (XJ and ZJ) in my club insist the other guys dont run 4.88 in d30s. they both installed 4.88s and within a year had stripped the pinion gears. when the ring gear is so small (like it is on a d30), the pinion has to get REALLY small to get the ratio that high (numerically). they push hard for the rest of the members to cap it at 4.56. its something to consider.
'88 XJ
post #15 of 28 Old 07-25-2011, 02:32 PM
Crasher
I've had 488s in my hp30 and 8.8 for 3 years now with some pretty serious rock crawling. I have an air actuated OX in the front and now, an ARB in the rear. No problems with either, but one has to use common sense to avoid a shock to the drive train. Don't let the front spin and don't get airborne. For highway running, I wouldn't want a lower ratio, even with my 5.2.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
