how 2 put 91' 242 in place of 98' 249 ? - JeepForum.com
post #1 of 9 Old 08-03-2009, 12:13 AM Thread Starter
shawn6666
just wondering if anyone has a 98 g.c. 5.2 and has put a 1991 242 case in place of the 1998 249, and what all was nececeray to do so. when i do the swap i will only have one day to do this so i just want to be prepared thank you!!!
shawn6666 is offline
post #2 of 9 Old 08-03-2009, 12:41 AM
xJoshxx
2012 WK
http://jeephorizons.com/tech/tcase.html
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 9 Old 08-03-2009, 03:04 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If the early tcase has a .840 input shaft it will bolt right in. If it is any other length you'll be in for a couple days misery.
ratmonkey is offline
post #4 of 9 Old 08-03-2009, 03:16 AM
sandman
the front half of the 249 will need to be mated to the 242. unless the gear cut and input length are the same then it will just bolt right up.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 9 Old 08-03-2009, 05:09 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Input length is all that matters for mating to the tranny. Gear cut is internal to the tcase.
If the input length is anything but .840 you need to swap front case halves like in the thread right below this one.
post #6 of 9 Old 08-03-2009, 05:22 AM
sandman
sorry im talking about spline count on the input shaft, but i guess everything 91 and up was the 23 spline? not sure. i just know when i did my swap the input shafts were the same length but the donor was a 21 spline so i had to swap it for my 249 23 spline shaft. i swapped over the whole planetary gear set, it was a 1993 to an 1989 case so the ring and sun gears matched up.
still though, his 91 case is going to have the different internal gear cut since the change over was in 94, so he will need to use the front half of his 249.
1993 Jeep ZJ. 4.0
sandman is offline
post #7 of 9 Old 08-04-2009, 01:34 PM Thread Starter
shawn6666
ok the input length is .840. So now i just have to swap the input shaft because the splines wont match up correct?
post #8 of 9 Old 08-04-2009, 08:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
unless you got it from a 4cyl it will be 23 spline.
post #9 of 9 Old 08-05-2009, 12:48 AM Thread Starter
shawn6666
it is a 4.0 L. cherokee sport
Best place for MT/R's Ubergrob ZJ Grand Cherokee Forum 13 12-10-2008 08:26 AM
Best place to buy OME? CrazyWalnut13 ZJ Grand Cherokee Forum 6 12-13-2007 12:06 AM
best place for UC BigItalianBeast ZJ Grand Cherokee Forum 3 02-10-2007 05:06 PM
where's the best place to get... OverlandMan69 ZJ Grand Cherokee Forum 1 08-25-2003 01:25 AM
5.9L in place of 5.2L YBSTUK ZJ Grand Cherokee Forum 12 11-03-2002 02:07 PM
