Hot out no Oil Pressure Cold out oil pressure - JeepForum.com
post #1 of 5 Old 07-22-2013, 08:07 AM Thread Starter
Mlarv
2014 JK Wrangler
howdy well my 96 ZJ with the 5.2 in it started acting up the other day when it got really hot here in OH. When it is cool outside the oil pressure is 50PSI or so but if it gets hot out above 95 the oil pressure drops to nothing the lights on the dash all light up saying no pressure but the engine runs fine no rattle. I have to put my foot on the gas at a light until it changes to get oil pressure up enough to shut off the lights. I am running 10W 30 I think it says on the cap. So what am I missing Can I run a mechanical gauge and disconnect the electrical one how do I get the lights to turn off if I do that? Or is there something just yelling at me to fix and I am to stupid to realize it? Thanks
What Would Scooby Do?
Mlarv is offline
post #2 of 5 Old 07-22-2013, 09:41 AM
Jeeples
Jeeples's Avatar
Replace the sending unit.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 5 Old 07-22-2013, 03:35 PM
wood04
you can read about this happening to various makes of motors, usually caused by worn main bearings. you can try a wix oil filter to raise some oil pressure or a heavier weight oil. also what are your engine temps?
wood04 is offline
post #4 of 5 Old 07-22-2013, 06:41 PM Thread Starter
Mlarv
2014 JK Wrangler
Engine temps are normal I know a main will cause low pressure but I have never seen one do it intermittently caused by out side temp. Thanks
Mlarv is offline
post #5 of 5 Old 07-22-2013, 09:17 PM
Oldfrog
2007 WK
Outside temp seeming to cause it would initially indicate to me that the problem is a bad electrical connection....so I'd check that sending unit first. They are cheap...so replace it and make sure the wiring is good.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
