hot air not comming out...interesting problem.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > hot air not comming out...interesting problem..
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 10-16-2009, 06:30 PM   #1
bnlhead1
so i have a 99 Grand Cherokee limited, with the dual climate controls.
i turned my heat on the other day and while there was air comming out of all the vents, the vents on the driver side was blowing cold air. the passenger was blowing nice hot air. interesting huh? when i switched the control to defroster, the air blowing was cool as well. at first i thought (and was told) that it was the thermostat, but once i figured out that there was hot air comming out of some of the vents and not others i guess that kind of debunked that theory. Anyone ever have this problem? or know what it could be?
bnlhead1 is offline   Reply With Quote
Unread 10-16-2009, 08:02 PM   #2
FPKites
ZJjazzyJim
FPKites's Avatar
This is a common problem with WJs, and can be difficult to search for since it comes up so much. Take a look here:
http://www.wjjeeps.com/hvac_sub_assembly.htm
Welcome to Jeepforum!
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Unread 10-17-2009, 01:51 AM   #3
Laidback
Nicely put! Lol
Laidback
Laidback is offline   Reply With Quote
Unread 10-17-2009, 08:51 AM   #4
FPKites
ZJjazzyJim
FPKites's Avatar
A link to the above write-up has also been added to the FAQ.
Jim Karlin
Unread 10-17-2009, 09:42 AM   #5
bnlhead1
OK...SO HERES AN UPDATE.
My father helped me and we pulled out the glove box and then pulled the actuator motor (i think thats what its called) out. he then manually turned the damper by hand and hot air started to come out of the driver side vents. So we figured all was well, i could get through the winter like this. well, i shut the car off and turned it back on and cold air come out the driver vents again while hot air was comming out the passenger side
