*hot air* blowing through vent even when set to cold - JeepForum.com
post #1 of 8 Old 03-13-2007, 01:34 AM Thread Starter
nori
My vent blows hot air even when set to the lowest temperature, not with A/C on. The vent is drawing heat directly from the engine compartment and I don't know what is causing this issue. I can also feel the hot air rising near the panels. If anyone here knows of this symptom and have any suggestions, I would be greatly appreciated.
Thank you in advance. My Jeep is 95' ZJ V8 5.2L. Please help.
nori is offline
post #2 of 8 Old 03-13-2007, 03:30 AM
micifus
Original GC'er
micifus's Avatar
check out this thread
http://www.jeepforum.com/forum/f13/automatic-temperature-zone-control-system-board-diagnostics-106446/
it will give you and us a better idea of what might be going on.
Then report back.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 8 Old 03-13-2007, 07:10 AM
wjs81866
wjs81866's Avatar
2011
your air door motor is probably not working right; I have the same issue. I have to replace the blend door motor on mine. But I guess it's a little easier then the WJ's since I don't have to remove the entire dash to do it.
1) 2011 Grand Cherokee LImited
Blackberry Pearl
5.7L
Quadra Trac 2
Lux Group 2
20" tires and rims
Towing package
2) 2011 Grand Cherokee Laredo X
Blackberry Pearl
5.7L
Quadra Drive 2
Quadra Lift
Laredo X Group 25 package
Chrome Fogs and Mirrors
Off-Road Adventure II Package
P265/60R18 Michelin LTX M/S 2's
BWoody 4" Velocity Intake
wjs81866 is offline
post #4 of 8 Old 03-13-2007, 03:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You could have a leak in your system. Try one of those refill cans at Wallyworld or any autoparts stores.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 8 Old 03-13-2007, 04:04 PM
ForwardControl
He says this is without the A/C. It does indeed sound like a bad door acutator (motor).
Matt
2000 WJ Laredo (Champaign), 4.0L, 242 SelecTrac. Added: Black front hooks. K&N FIPKII Intake. RB1 Navigation, Mopar iPod Integration. 31" BFG All Terrain T/A KO. Alpine audio upgrade (see link below). Next: IRO 3" Lift, new shocks.
I HAVE A 4.0L In My WJ And LOVE It So *** Me Club Member #1
Colorado Jeep Club Member #114
ForwardControl is offline
post #6 of 8 Old 03-13-2007, 04:06 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Or, it could just be the outside ambient temp is warm?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 8 Old 03-13-2007, 06:26 PM Thread Starter
nori
Thanks alot for the link micifus and other's comments. I'll first run the diagnostic test today and post the result here. The ambient temperature outside is pretty cold, and I'm almost certain that this heat is coming directly from the engine.
Before going further into this, I'll run the test first, but just wanted to say thanks for the advices. Will post the result soon. Thanks again.
nori is offline
post #8 of 8 Old 03-14-2007, 06:56 AM
wjs81866
wjs81866's Avatar
2011
When it's 30 deg outside mine blows warm air from the vent; on a warm day if I turn the A/C on it's almost comfortable. You are getting warm air due to the door not positioning as it should based on the control unit settting.
Blackberry Pearl
5.7L
Quadra Trac 2
Lux Group 2
20" tires and rims
Towing package
Blackberry Pearl
5.7L
Quadra Drive 2
Quadra Lift
wjs81866 is offline
found out it was blowing gear oil out the vent tube lance70 WK Grand Cherokee & XK Commander Forum 6 10-12-2009 11:56 AM
AC blowing cold and hot! mbquart ZJ Grand Cherokee Forum 7 06-30-2009 11:24 AM
Cold air only blowing out lower vent Vestjam ZJ Grand Cherokee Forum 20 07-10-2008 08:33 PM
Air Vent not Blowing as Hard tbm5690 ZJ Grand Cherokee Forum 1 01-22-2008 05:54 AM
Vent blowing hot air when cool out???? spr ZJ Grand Cherokee Forum 9 09-06-2005 02:16 PM
