Horn problem - JeepForum.com
post #1 of 9 Old 07-08-2013, 12:11 PM Thread Starter
Dubfire98
Horn problem
Ok so I've used the search function to no avail on this one. When I got my 96 zj, the PO had taken the horns off to stop the alarm from going off and waking his neighbors. So now I went and got a single aftermarket blaster horn. Hooked it up to one set of wires... I hear the relay clicking but no sound. So I hook both sets of wires to it, still nothing. Any help would be great.
Dubfire98 is offline
post #2 of 9 Old 07-08-2013, 01:00 PM
BrandonsZJ
Make sure you have the green/yellow wire connected to the power wire and the black wire connected to the ground from the stock connector. I messed that up when I installed my horns.
BrandonsZJ is offline
post #3 of 9 Old 07-08-2013, 01:03 PM
airwolf9090
Also check for voltage at the horn, Might of just got a bad horn lol
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #4 of 9 Old 07-08-2013, 01:42 PM Thread Starter
Dubfire98
I've tried everything. I'm assuming my zj came with dual horns as I have 2 sets of yellow/green and blue wires. I tried wiring them together, color to color then to the horn. Still nothing. The relay is clicking. Mayb I did get a bad horn
post #5 of 9 Old 07-08-2013, 02:47 PM
airwolf9090
I would still check for voltage! Is no volt meter if you got a riding mower pull its headlights well really just one with the socket and set it where you can see it then use a set of jumper wires to hook it up and push you horn and see if it comes on.
1996 Jeep ZJ Orvis
post #6 of 9 Old 07-08-2013, 07:50 PM Thread Starter
Dubfire98
UPDATE: the "new" blaster horn was bad. Took it back and swapped it out for another and it works just fine. I guess it is possible to get a bad "new" horn.
post #7 of 9 Old 07-08-2013, 07:57 PM
Kevinyj95
Wow no horny jeep jokes?
Kevinyj95 is offline
post #8 of 9 Old 07-08-2013, 08:17 PM
dnuccio
my jeep is very horny. its got 2 sets of 4 tone cadillac horns. waaahhhh waaaahhhhh
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 9 Old 07-09-2013, 01:07 PM
airwolf9090
Wish i could remember what caddy came factory with air horns to put on mine! lol
1996 Jeep ZJ Orvis
