01-28-2007, 12:07 PM
#1
Hi. Has anyone put an old-fashioned prop rod in their Jeep? My Grand Cherokee's hood supports lost their life a long time ago. If I'm home working on it, I usually find something in the garage to keep hood open.
I'd like to hear others' ideas on this because I'm sure a lot of people have the same problem. Looking to hear any and all feedback, but not looking to replace the hood struts with same.
Thanks.
01-28-2007, 12:12 PM
#2
well my zj has got the spring ones and they seem like the never fail, you could try to fab in some springs in like the zjs
if you need a picture of them i can get one for you
-Andy-
06-tj-2.4 4 cyl, 6 speed. red, 2.25 bb on 31s, rear aussie locker, hella 500 series on bumper, mile marker pe8000, rock krawler rear bumper w/ hitch, optilux lights mounted on stainless steel windshield light brackets, in cab winch switch
red jeep club member 479
http://www.myspace.com/legend6009
my myspace^
01-28-2007, 12:14 PM
#3
Retired back to Bowties
WJ's use lifting shocks. Another bad call by Chrysler.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
01-28-2007, 12:29 PM
#4
I am lazy and like you my shocks went out a long time ago, i just use the handle to a floor jack i have. i think it works really well, has an open end that fits over the head of a nut and the rubber handle makes sure it doesn't slide on the hood.
2000 WJ Laredo
4.7L Quadra-Drive
01-28-2007, 03:46 PM
#5
Thanks.
Why? They're like $20 a piece to replace. That's what, a single tank of gas?
I replaced my originals at 60K miles and now at 97K the replacements are still fine.
01-28-2007, 04:06 PM
#6
were u getting gas if it cost you $20 for a full tank hahaha
01-28-2007, 04:15 PM
#7
Just not lookin' to add same junk to the vehicle. My set went out at probably around 30K. I'd rather put the $40 to another use.
01-28-2007, 04:44 PM
#8
orielly's are lifetime warranty... i have been thinking about some for my hatch, but ,like you say 40 bucks is 40 bucks..
If you know where you bought them take them back. most places use your phone numbers for proof that you have purchased stuff
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
01-28-2007, 05:08 PM
#9
do the math...
20 dollars for one shock
+ 20 dollars for the other
= 40 dollars
there are two lift shock on the hood.
40 bucks equals about a tank of gas.
I could kind of see if you were putting it on a crappy 20 year old vehicle to retro fit a proprod on, but your 2000 WJ is still a newer vehicle. I guess you could go through the trouble to pay to go into a junk yard, yank off a prop rod off an old F150 or similar sized truck, then pay them another couple of bucks to buy it. then take it home, figure out what points to drill into your body and then in the hood and make sure it fits and will lay down, extend, and seat properly with out issues and and at the correct angle... only to likely ghetto rig it after a few failed attempts. if you dont care to spend the 40 bucks or less for shocks I'm guessing you would give up on the prop rod idea half way, only to end up using a hammer or rubber mallet that you probably yanked from your tool box and keep in your jeep or when you need to look inside, wedging it in between body and hood.. just hope that the hammer doesnt slip off and the hood falls on your head, trust me it hurts... do your self a favor and get the shocks on ebay for 31 bucks plus 6 bucks shipping and you'll save your self all the trouble
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
01-28-2007, 05:09 PM
#10
the aftermarket shocks from like autozone or what ever have lifetime warranty also, so in theory its the last 40 you will have to spend on hood shocks.
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
01-28-2007, 05:20 PM
#11
I would get the shocks. I don't know about you, but $40 is a couple of pizzas, a few days of fast food, all sorts of things that money gets wasted on that would be better served keeping the hood from braining you, and it will. Ghetto prop rods always fail when you don't want them to...
01-28-2007, 05:31 PM
#12
I have never seen a prop rod fail. Whether it be a bent one, rusty one, 2x4 broomstick, whatever. Still the gas props can be picked up at autozone.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
