Homemade ZJ Disconnects - JeepForum.com
Closed Thread
post #1 of 17 Old 02-28-2008, 09:02 PM Thread Starter
Cha Cha
ZJ Homemade Swaybar Discos
Here are some low cost front swaybar disconnects that I made and thought I would share how I made them.
Items needed: atleast 6" of 1 1/4" X 1/8" steel, 2 Air hose couplers, 2 sway bar links, and some common sense.
Start out by cutting some 1 1/4" X 1/8" rolled steel cut into two 3" strips. http://i180.photobucket.com/albums/x...mmer070025.jpg After it is cut use your trusty 4lb. sledge to bend in half at a 90 angle. http://i180.photobucket.com/albums/x...mmer070026.jpg
Then drill two 1/2" holes in each side one for the mounting bolt and one for the air hose coupler that serves as the disconnect point. After the holes are drilled then put the female part of the coupler in on of the holes and either bolt or weld it on. http://i180.photobucket.com/albums/x...mmer070029.jpg
After this move on to the links if you have stock links I would cut off the threaded end and buy or make some thing to utilize the bushing so it will fold up and out of the way when disconnected. http://i180.photobucket.com/albums/x...mmer070032.jpg After you have cut it to the desired length, thread it or weld it into the male part of the air coupler. http://i180.photobucket.com/albums/x...mmer070034.jpg
Then put a fresh coat of rattle can on it in your desired color. Install and admire the simplicity and ease of use. http://i180.photobucket.com/albums/x...mmer070035.jpg
95 ZJ limited
5.5" lift, 33" TrXus.
Cha Cha is offline
post #2 of 17 Old 02-28-2008, 09:05 PM
tennesseewj
mehh that's no good
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #3 of 17 Old 02-28-2008, 09:06 PM
tsconver
2003 WJ
His links are all broke, lol
He fixed them and what a horribly dangerous bad idea. THose will brake under pressure and kill someone.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #4 of 17 Old 02-28-2008, 09:09 PM Thread Starter
Cha Cha
They should be fixed.
95 ZJ limited
Cha Cha is offline
post #5 of 17 Old 02-28-2008, 09:10 PM
tsconver
2003 WJ
you need to delete this before someone does it and gets killed, horrible idea.
A few goodies
2006 Red Liberty
tsconver is offline
post #6 of 17 Old 02-28-2008, 09:27 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
cha cha,
I believe that you wouldn't die from this. However, your suspension mod could fail. If it does, it'll chose to do so at a very bad time. Why chance that? Yes, getting the proper parts is a bit more expensive but, worth every single penny of not having to worry that it will break.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 17 Old 02-28-2008, 09:29 PM Thread Starter
Cha Cha
These were designed for off roading, light road use and for ease of disconnection. I apreiciate the feed back and will reconsider my design. It was free anyway.
95 ZJ limited
Cha Cha is offline
post #8 of 17 Old 02-28-2008, 09:34 PM
tsconver
2003 WJ
Do you drive the vehicle on the road? If so imagine going around a highway ramp at 55mph, the amount of force on the sway bar is way more than those disconnects were made to hold. Now in that same corner imagine it popping loose and you either roll teh jeep or have to counter steer to correct the sudden change in roll of teh body and cause a wreck. They are not safe and could kill someone.
A few goodies
2006 Red Liberty
tsconver is offline
post #9 of 17 Old 02-28-2008, 09:36 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Aside from the fact that these couplers are not meant to be subjected to the stress this use will put them under, and they will live a short life...have you ever tried to connect an air hose when the coupler is packed with dirt and mud? I don't see this being very easy to use after a day of wheeling, when it's time to reconnect.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #10 of 17 Old 02-28-2008, 09:37 PM
Virmagicus
Virmagicus's Avatar
Hey Cha Cha , You did not answer my question on your last "new thread" that Arlo deleted for trying to sell them. Will these also add air in the tires ??? I ought to hook up my Paslode and ....ever see that movie Lethal Weapon ?
Jeff
Virmagicus is offline
post #11 of 17 Old 02-28-2008, 09:42 PM
CLNinja
CLNinja's Avatar
do a search on here or JU or one of these forums... someone made homemade discos and it was actually a safe design... if you want to go the cheapo route find that post
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #12 of 17 Old 02-28-2008, 09:47 PM
CMARJEEP
CMARJEEP's Avatar
you have to give it to him though, although unsafe and possibly deadly, it was a pretty good idea.
CMARJEEP is offline
post #13 of 17 Old 02-28-2008, 09:51 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
$70 bucks and no safety issues.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #14 of 17 Old 02-28-2008, 09:54 PM Thread Starter
Cha Cha
Thanks those are $70 more than the ones I built. Who are they made by?
95 ZJ limited
Cha Cha is offline
post #15 of 17 Old 02-28-2008, 09:58 PM Thread Starter
Cha Cha
Since you guys like these so much i might as well start selling them, how does $115 a pop sound?
95 ZJ limited
Cha Cha is offline
Closed Thread
Disconnects JBN311 WJ Grand Cherokee Forum 15 04-21-2010 03:38 PM
Homemade quick disconnects cause death wobble? jeepgc99lmtd ZJ Grand Cherokee Forum 17 12-19-2009 12:49 AM
disconnects? Reloader77724 ZJ Grand Cherokee Forum 12 08-10-2006 01:49 PM
Homemade disconnects for a WJ? RobertTF ZJ Grand Cherokee Forum 2 11-23-2005 08:37 PM
