Home made sliders-How to attach? - JeepForum.com
post #1 of 28 Old 06-20-2009, 09:37 PM Thread Starter
ZeJokee
I am in the process of making a set of sliders for my ZJ. My question is how should I attach the to my ZJ? I don't have pics at the moment. I was thinking about using grade 8 bolts are something to attach them to the frame and small bolts to attach it to the pinch seam. Any suggestions?
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #2 of 28 Old 06-20-2009, 09:37 PM
gatorayde
Weld them? Otherwise grade 8 for sure on the pinch and frame.
gatorayde is offline
post #3 of 28 Old 06-20-2009, 09:41 PM Thread Starter
ZeJokee
I am not going to weld them to my jeep, encase I ever want to remove them. Running bolts threw the frame will not weaken the unibody at all?
ZeJokee is offline
post #4 of 28 Old 06-20-2009, 09:43 PM
gatorayde
Unless you drill 1000 holes in it, no.
post #5 of 28 Old 06-20-2009, 09:46 PM
xJoshxx
2012 WK
yup Use little bolts as possible Make them BFB tho's
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 28 Old 06-20-2009, 09:59 PM
elmer_fud
look at the install instructions at JCR/IRO/kevins/ect to see how they mount sliders and use the same method.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #7 of 28 Old 06-20-2009, 10:05 PM Thread Starter
ZeJokee
Well, I will be finishing welding them together tomorrow and should have pics of the finish product too.
ZeJokee is offline
post #8 of 28 Old 06-20-2009, 10:10 PM
sandman
use self tapping bolts in the frame and use self tapping screws in the pinch seam. thats exactly how 99% of the aftermarket ones attach.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 28 Old 06-20-2009, 10:14 PM Thread Starter
ZeJokee
I am afraid the self tapping bolts might eventually pull out.
ZeJokee is offline
post #10 of 28 Old 06-20-2009, 11:21 PM
sandman
you would think but if the slider is designed right and resting on the rocker youll be fine KORs sliders use self tappers and are pretty much indestructable, i dont know of one company that runs a bolt or sleve through the frame.
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 28 Old 06-20-2009, 11:27 PM Thread Starter
ZeJokee
I'll use self tapping bolts on the frame and regular bolts on the pinch seam. That should hold it, if not I will just reinforce it till it holds.
ZeJokee is offline
post #12 of 28 Old 06-20-2009, 11:31 PM
sandman
not sure if youll be able to use regular bolts on the pinch seam, access to the outside of the pinch seam will be tough to impossible once the slider is on.
1993 Jeep ZJ. 4.0
sandman is offline
post #13 of 28 Old 06-20-2009, 11:38 PM Thread Starter
ZeJokee
I might have enough room how I am building mine, I will have to check in the morning, either way I am getting the them on my jeep tomorrow!
ZeJokee is offline
post #14 of 28 Old 06-20-2009, 11:39 PM
sandman
good to hear, please post pics when your done!!!!
1993 Jeep ZJ. 4.0
sandman is offline
post #15 of 28 Old 06-20-2009, 11:40 PM
Virmagicus
Virmagicus's Avatar
You do not want to go through the "frame" with a carriage style faster. I made mine and welded them on and could have the sliders off in 15 minutes. They are 3/16" with 1/4" arms. You just want to stitch weld them on. Small 1/2" weld let cool etc .. If you are totally against welding them just use the high grade self tapping bolts. Drilling holes will weaken the unibody some but a few in each mount does not matter. You will want to drill out the mounts first and then drill small holes 1/8"-3/16" for the self tappers to make it easier. Did you run a piece of angle or flat stock for the pinch seam/body ?
Jeff
Virmagicus is offline
Home made Rock Sliders? sage39henry ZJ Grand Cherokee Forum 1 02-05-2010 04:34 PM
Who made their own rock sliders?? TheSandman ZJ Grand Cherokee Forum 15 08-25-2009 06:54 PM
home made intake? BurtonRyder ZJ Grand Cherokee Forum 8 06-17-2009 12:08 AM
new hand made sliders jeep946 ZJ Grand Cherokee Forum 33 02-27-2006 10:28 AM
For Those who have made their own Sliders OffroadZJ ZJ Grand Cherokee Forum 0 07-08-2005 10:49 PM
