-   -   hole in tranfer case? (http://www.jeepforum.com/forum/f13/hole-tranfer-case-1237772/)
1Dirtymudder 07-10-2011 10:02 AM
I was wondering if any of you guys could give me some insight on this. It appears that i've got a hole in the bottom of my transfer case. How tough is this to fix? Can I just get the front part of the case and replace that. How much do you think a shop would charge? I have a '94 zj (all time 4x4)
http://s1176.photobucket.com/albums/...t=IMG_0304.jpg
http://s1176.photobucket.com/albums/...t=IMG_0303.jpg
Looks like it's just the front plate.
KingtheZJ 07-10-2011 02:33 PM
i would just get a new case. you can get them from 100-300 from junkyards and you can move to a 242 while youre at it. look at the sticky thread about the tcase swaps that is in the ZJ section.
1Dirtymudder 07-10-2011 02:57 PM
Do you think a little JB weld or similar product could buy me a few months. As it is, it only leaks a bit. I've been keeping tabs on the fluid level and haven't had to add any in a while. I'm installing a 4.5" lift on it next week and some 33s. I'd like to have time to road test that for a bit before i tackle the transfer case. What is better about that other one? The 242.
1Dirtymudder 07-10-2011 03:06 PM
I just found this thread. It says the hole is supposed to be there. ???? Is this right because although it's in the same spot, my hole looks pretty irregular. Like it wasn't intended to be there. But if that's true, it changes the whole JB weld game huh?
http://www.jeepsunlimited.com/forums...d.php?t=218687
3xX 07-10-2011 05:34 PM
That's correct, the hole is supposed to be there. It's a weep hole. If it's leaking you likely have a bad input or output shaft seal. Best to replace both at the same time.
1Dirtymudder 07-10-2011 06:53 PM
Thanks for your help, I'll look into it
The time now is 07:50 PM.
