Hole in Exhaust, how to repair? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Hole in Exhaust, how to repair?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 10-18-2007, 06:46 AM   #1
micifus
Original GC'er
micifus's Avatar
Other then welding what is a good product to repair a hole in ones exhaust? I have a hole in my exhaust by the cross member
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Unread 10-18-2007, 07:02 AM   #2
greasefingers
1994 ZJ
Don’t do that. Once you fix the hole the muffler will blow!
Actually I have wrapped a cloth and cement type adhesive, made just for this, around exhaust pipes but the two times I did this they failed shortly ( days to two weeks) after mending.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 10-18-2007, 07:18 AM   #3
nashmd454
I was st etting ready to suggest that very same thing...if he went to n auto parts stor they have exhaust repair kits...I never heard of that happening before. That is a new one.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Unread 10-18-2007, 07:33 AM   #4
JayJEEPguy
Isn't the entire exhaust system (Kolak's) new?
Jason T.
'05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote
Unread 10-18-2007, 08:27 AM   #5
micifus
Original GC'er
micifus's Avatar
Lets not go There!
to make a long story short on the exhaust system. No one would put the system on saying it did not fit. When i did find someone to it
(A national chain with a team of Window Lickers for employees.) They Bleeped it up soooo bad. they clamped it, put everything at the wrong angle, never insatlled a hanger of the TC, and put the cross member support above the cross member so it constanly bangs off it. the CM support go ripped off when I dropped the TC for the swap so that is where I have a hole in my exhaust system. I shold take pics you will want to through up in your mouth. Shes already got one tire in the grave so I am just passing time till she dies and I have the money for a WJ.
I took it to "my mechanic" who said he wouldnt dare touch it, he kind of pissed me off too by chargeing me $28 for a tire roataion. I was thinking around the lines of 10 bucks since it was there for an inspection and he was way into a tire rotation any way.
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Unread 10-18-2007, 10:27 AM   #6
greasefingers
1994 ZJ
It could be TIG welded with some work. My friend did this: A small square section (like 1”x1”) was cut from an old exhaust pipe of the same diameter (that way the curvature is maintained) and it gets wire wheeled on both sides to provide a clean surface. Then the curved square section is tack-welded over the hole. Instead of running a continuous bead all the way around the perimeter, he instead made numerous tack-welds until the tacks formed a continuous bead. That way he did not risk burned thru the very thin gage metal.
I know you stated other then welding … for solutions but I thought I would share one way that I know worked.
Of course finding someone willing to help/work in this way may be difficult to find.
Cheers Steve
Unread 10-18-2007, 11:43 AM   #7
driabyor
1994 ZJ
cut a piece of metal bigger than the hole.. a little bit of muffler goop ... and a couple muffler clamps .... clamp gently as not to distort the new metal or pipe.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Unread 10-18-2007, 01:13 PM   #8
Katesdad
Katesdad's Avatar
soup can it
Katesdad is offline   Reply With Quote
Unread 10-18-2007, 01:27 PM   #9
FortCollinsZJ
Duct tape? the metal stuff for duct work. that'll do it.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Unread 10-18-2007, 01:48 PM   #10
greasefingers
1994 ZJ
Originally Posted by Katesdad
soup can it
Campbell’s or Progresso soup?
Cheers Steve
Unread 10-18-2007, 01:57 PM   #11
-Joe-
Just remember to completely remove the rice from the can!
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Unread 10-18-2007, 02:05 PM   #12
driabyor
1994 ZJ
I don't know if I would use a can that had rice in it..... You wouldn't want a Jeep sounding like a Honda... Now ,would you?...
5.2 liter 242 :)
Unread 10-18-2007, 02:06 PM   #13
driabyor
1994 ZJ
Use just half the can ...
the half you can use to make a turbinator
5.2 liter 242 :)
Unread 10-18-2007, 02:11 PM   #14
BucYouUp68
Depends on the size of the pipe.
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline   Reply With Quote
Unread 10-18-2007, 03:03 PM   #15
ZJ_Dave
Or even better, use gorilla tape. That stuff is strong as hell.
Is it summer yet?
'98 ZJ! 4.0L Laredo, with some upgraded stereo stuff.
Great pictures! Now I know what she looks like naked.
ZJ_Dave is offline   Reply With Quote
