Quantcast Hole in exhaust - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Hole in exhaust
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 11-30-2007, 08:46 AM   #1
micifus
Original GC'er
micifus's Avatar
Hole in exhaust
I need to patch a hole in my exhaust will JB weld hold up to the heat? I know someone here patched there cracked header how did it hold up?
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 11-30-2007, 10:56 AM   #2
greasefingers
1994 ZJ
Go for it man!
JB weld is amazing stuff. I would try it and see how it holds. I have no experience with it and heat. The outside of the muffler is not as hot as one would think. The exhaust manifold inside gas temp is freckin hot!
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 11-30-2007, 11:06 AM   #3
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
People using it on their exhaust manifold say it only holds for a week or so...
ArloGuthroJeep is offline   Reply With Quote
Old 11-30-2007, 11:14 AM   #4
Zlartibartfast
If you want it really fixed, it'll need to be properly welded. That means removing it from the block. If you're going to that much effort, get a proper header to replace it.
You can use JBweld as a temporary patch; just clean the metal surface thoroughly, and plan on repeated applications
Zlartibartfast is offline   Reply With Quote
Old 11-30-2007, 05:55 PM   #5
greasefingers
1994 ZJ
Where exactly is the hole? Header, pipe, or muffler?
Cheers Steve
Old 11-30-2007, 07:33 PM   #6
brsox88
2005 WK
I would buy an exhaust clamp sleeve. Then buy some exhaust putty or glueish type stuff. Lay that inside the sleeve and put the sleeve over the whole. Best cheap way to fix a hole in an exhaust.
brsox88 is offline   Reply With Quote
Old 11-30-2007, 09:26 PM   #7
Country Boy
Bovi-sapiens
Country Boy's Avatar
JB will work on the rear parts of the exhaust system, but not near the manifold. I put some on my manifold and it lasted all of 3 minutes. I found a product called Thermosteel that seems to be working. I put it on two weeks ago and its just as hard now as then. You put it on and let it cure for 3-4 hours, then slowly heat it to fully cure it. I got mine at Advance Auto Parts. The product claims to be able to withstand 2400* F. It was about $6 for a small jar.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline   Reply With Quote
Old 12-01-2007, 04:19 AM   #8
melonman
Hey Silver Stihl,
Let us know in like a month if it is still holding up. Where is your patch located? I have tried as couple things on the infamous exh. header collector crack / leak on my '96 I6 and they might last like a month but it is so hot right there-I didn't really expect to hold and it is so hard to get the patching compund / wrap etc. in and around where the leakage is (multiple pipes come together) so getting a good patch is next to impossible to begin with. I might want to try that thermosteel stuf but wanted to see if you were using it in an intense type location or not.
Thanks,
Larry
melonman is offline   Reply With Quote
Old 12-01-2007, 08:13 AM   #9
Country Boy
Bovi-sapiens
Mine is right where the last two pipes come together before the down pipe attaches to the header. I just used my finger to scoop it out of the jar and worked it into the cracks. I ended up putting it all the way around both pipes instead of just the cracked one. I'll keep you updated on it, but using that product and replacing my O2 sensors took care of all the problems I was having with my ZJ. It drives like a dream now. I have a feeling the O2 sensors were bad because of the excess fuel being dumped into the system causing excessive buildup of soot on the sensors.
Glock Forum
