hogh voltage 02 sensor/bad cool sensor - JeepForum.com
post #1 of 1 Old 01-24-2010, 10:33 AM Thread Starter
Jh24k
1998 WJ
I have a 98 grand cherokee 5.9. Recently my check engine light turned on. I had I checked. It said high voltage 02 sensor bank 1 sensor 1(been running choppy and flooding out or gas starved). So I decided to replace both since the truck has 200k on it. To my dismay it did not solve the problem(I did reset code). I also bad coolant sensor reading on dash(changed and still did not remove error mess). Could the two issues have something to do with the other? Please help(would be greatly appreciated) before I decide to get medival on it.
Jh24k is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 12:01 AM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 09:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
Error P0122: Throttle Position Sensor Voltage Low. TimeOut ZJ Grand Cherokee Forum 4 11-06-2005 08:28 AM
