hitch mounting question - JeepForum.com
post #1 of 4 Old 05-03-2013, 01:17 PM Thread Starter
AmishFury
i'm helping a friend get a hitch he pulled from a junkyard onto his ZJ and i'm noticing on one side the studs are slightly bent towards the tank and the other side they appear to have been ripped out completely
i'll try to get some pics as soon as i can but i definitely could use some suggestions here the side with the studs missing the holes are bent outward and the surrounding metal is a bit bent
AmishFury is offline
post #2 of 4 Old 05-03-2013, 01:51 PM
kg6mov
Hears the voices
kg6mov's Avatar
Sounds like it took a major rear end hit. If you get hit with a hitch it bends the unibody all out of shape.
kg6mov is offline
post #3 of 4 Old 05-03-2013, 03:02 PM
Afdude88
X2. Sounds like that zj isnt getting a hitch
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee: 4.0L I6, 42RE, np249 (ugh), stock (ugh)
Afdude88 is offline
post #4 of 4 Old 05-05-2013, 10:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you could get it lined up i wouldn't tow anything more than a bike rack with it though. that zj probably took a hard hit with a hitch already installed previously.
ratmonkey is offline
