Hit a deer, put it back to together, now its overheating? - JeepForum.com
post #1 of 13 Old 04-27-2012, 10:11 AM Thread Starter
SteveMan88
Hey y'all, I'm new here. I have a 1996 Grand Cherokee with 245,000 miles on a 4.0L. I am not a great mechanic so all the help I can get is greatly appreciated.
My question is: I hit a deer a few months back. I took it all apart and ended up replacing the Water pump, fan clutch, fan shroud header panel, hood, grill, radiator and thermostat. I test drove it the other day and its running rough so I am thinking the timing chain might have slipped on the impact (I was doin about 50) but the real puzzling part is that it's still overheating even with a new water pump, thermostat, and radiator?
Could this be linked to the timing chain slipping?
Plus when it overheats the first place I see steam is at the valve cover on the drivers side towards the middle.
SteveMan88 is offline
post #2 of 13 Old 04-27-2012, 10:13 AM
ZJMTL
Kinda sounds like a head gasket, but I will let one of the more experienced guys chime in, because I am terrible at e diagnostics. How is your coolant level?
ZJMTL is offline
post #3 of 13 Old 04-27-2012, 11:19 AM
Slim57
1994 ZJ
Are you sure none of your lines are crimped? Any, I meany any leaks?
Slim57 is offline
post #4 of 13 Old 04-27-2012, 12:34 PM
paulyboy
when you replaced and filled the system up did you bleed air out? could be as simple as air stopping the coolant flow and causing it not to circulate i.e. overheat. I would look into that first.
ENTER WITTY COMMENT HERE ________________
paulyboy is offline
post #5 of 13 Old 04-27-2012, 12:57 PM
Slim57
1994 ZJ
Agreed. I failed to mention this in my previous post. If you have not "burped" the system, there is probably an air pocket somewhere in there stopping coolant from circulating.
Slim57 is offline
post #6 of 13 Old 04-27-2012, 01:06 PM
speedbucket
yep
pop radiator cap
let it run untill it reaches operating temp and t stat opens
you will probably see and empty radiator when this happens
top off the radiator and repeat until the radiator stays topped off at operating temp
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 13 Old 04-27-2012, 02:13 PM
edpmedic
I thought you put the Deer back together and it had s high temp.
Rough running could be from disconnecting the battery to do the work. Mine ran rough for a couple of days after I did the pump I took it on the highway and it is smooth now. Does it feel like a miss at speeds or just rough at idle. Chances are if the chain slipped it would be back fire and not running. Very rare does it just run rough.
I would also check for cracked vacuum lines
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #8 of 13 Old 04-27-2012, 02:26 PM
Slim57
1994 ZJ
Also a good idea to park the jeep on a slight incline when you burp the cooling system (you want the front of the jeep pointing up the incline. This will help the air escape.
Slim57 is offline
post #9 of 13 Old 04-27-2012, 03:13 PM
gearheadnick
An even easier way to get the air out of the system is to spend 5 bucks and install a flush and fill kit on the highest point of the cooling system (a heater hose). Remove the flush cap, and fill the radiator until the coolant just starts to come out of the fitting. Cap it, fill the radiator the rest of the way, and you're done.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #10 of 13 Old 04-27-2012, 03:22 PM Thread Starter
SteveMan88
Thanks y'all! Gonna try it tonight hopefully I don't have to do the timing chain because that just sounds like more fun than I wanna have
post #11 of 13 Old 04-27-2012, 09:28 PM Thread Starter
SteveMan88
hey y'all the jeep is back on the road and working great! Thanks for all the advice! I took it out this evening after I burped the system. Drove it through town and down the busiest area with lots of stoplights then out on the highway for about 10 miles stopped and got gas and checked the radiator again drove the 10 miles home and no problems! had it up to 80+ mph (keeping up with traffic and all lol Thanks again y'all!
post #12 of 13 Old 04-27-2012, 09:46 PM
paulyboy
easy no cost fix is the best fix
paulyboy is offline
post #13 of 13 Old 04-30-2012, 06:40 AM
Slim57
1994 ZJ
Glad it worked!
Slim57 is offline
4.0l , hit a deer , new here , overheating , timing chain
Hit a deer with my jeep Dodgeram1989 ZJ Grand Cherokee Forum 47 03-17-2011 06:04 PM
Hit a deer SGT Superman ZJ Grand Cherokee Forum 11 01-26-2009 01:45 PM
Deer.. Inavacuum ZJ Grand Cherokee Forum 20 05-17-2007 03:02 PM
D$%M Deer matts98ZJ ZJ Grand Cherokee Forum 4 06-10-2006 02:00 PM
Hit a deer going 80 dwills898 ZJ Grand Cherokee Forum 12 03-09-2006 12:30 AM
