Hissing brake pedal when cold...problem? - JeepForum.com
post #1 of 5 Old 03-23-2006, 02:03 PM Thread Starter
sethdallob
I have a 99 WJ, and after I press the brake pedal and release, it hisses at me. After a while (couple minutes), it goes away. If I push the brake pedal down even slightly, the hiss goes away. It brakes just fine, whether hissing or not. Any ideas?
sethdallob is offline
post #2 of 5 Old 03-23-2006, 05:49 PM
Varkyl
No where near stock
Varkyl's Avatar
Have you checked under the dash to see if you have a snake hiding under there?
Anyways, it sounds as though your vacuum booster may have a slight leak in it. Maybe another WJ owner can verify if this is normal or something to investigate.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #3 of 5 Old 03-23-2006, 08:59 PM
Robinton
The booster draws in the air under the dash when you apply the brakes. There's supposed to be a foam silencer in the end of the booster to silence the hiss, over time the silencer deteriates and disappears. This is probably what's causing the hissing. It causes no problems except for some irritating noises.
Robinton is offline
post #4 of 5 Old 03-24-2006, 12:04 AM Thread Starter
sethdallob
Thank you, that is a relief.
post #5 of 5 Old 03-24-2006, 11:50 AM
Vancopbs
The foam filter quites the booster as you apply it. So when you press the pedal down the filter quites it. If it hisses after you relase the pedal, or hisses without you touching the pedal the booster is bad.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline
Brake booster hissing twistedgalant ZJ Grand Cherokee Forum 4 02-03-2010 06:17 AM
Stiff Brake Pedal CLNinja ZJ Grand Cherokee Forum 3 02-02-2010 11:41 PM
brake pedal mushy macwig52 ZJ Grand Cherokee Forum 3 03-05-2009 03:53 PM
Hissing sound behind steering wheel - got cold last night dickensheets ZJ Grand Cherokee Forum 2 11-30-2008 06:57 PM
Problem with brake pedal? luke4x4 ZJ Grand Cherokee Forum 8 03-17-2006 06:51 PM
