High Pinion D30 question - JeepForum.com
post #1 of 4 Old 03-28-2008, 06:28 AM Thread Starter
Lud04X
Just wondering if the Grand Cheorkees came with a high pinion D30 up front and figured I'd ask the experts in the ZJ/WJ forum.
I found a 1997 Grand Cheorkee front axle for cheap in my area and am wondering if its high pinion or not.
I have a 2004 Wrangler and am looking to upgrade the low pinion D30 I have up front. I'm looking to put in an ARB in it as well. I know the gears are reverse cut so I'll have to get new ones.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #2 of 4 Old 03-28-2008, 07:00 AM
Darthteddy
1955 M-38
Grands didnt, but some XJs (Cherokees) did.
Cant help you on the gear stuff tho.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #3 of 4 Old 03-28-2008, 09:08 AM
sandman
yea you wont be able to swap over the gears. depending on your ratio you may be able to find an hp30 match.
1993 Jeep ZJ. 4.0
sandman is offline
post #4 of 4 Old 03-28-2008, 09:19 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i am gona say that proably 90% or so XJs had HP30s, the only years that didnt was 2000 and 2001.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
Swapping a High PINION D30 into my ZJ hebijake ZJ Grand Cherokee Forum 9 12-17-2009 10:05 PM
Looking for Ford High Pinion dana 60 front Need help eshew ZJ Grand Cherokee Forum 1 03-03-2009 11:28 PM
high or low pinion 30? spidermonkey ZJ Grand Cherokee Forum 2 11-14-2008 11:48 AM
Ring and Pinion question keeth1123 ZJ Grand Cherokee Forum 9 05-29-2008 01:41 PM
D30 High Pinion Question XJAdventure ZJ Grand Cherokee Forum 5 02-09-2008 08:35 AM
