11-17-2008, 10:13 PM
#1
High Output Altinators For WJ?
I need a high out put for my WJ for 6 lights subs and winch. Who makes a good one for the 4.7L?
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
11-18-2008, 12:04 AM
#2
Look at Mean Green alternators...
Why do you think you need a new one though? Is it not keeping up with electrical demand? WJs already come with pretty large alternators.
11-18-2008, 12:13 AM
#3
You're better off just going to a stereo shop and asking them. They definitely know how to handle electrical systems that draw a lot of power.
Meh...
11-18-2008, 07:44 AM
#4
im gunna try and use the stock one but im pretty sure i will need more power with 8 lights and a winch.
11-18-2008, 08:19 AM
#5
I feel your pain my 03 4.7 needs a larger alt. With heated seats, heated windsheild washer fluid, defroster, lights on, an two amps it can drag the output down to like 10 volts at a stop light and sits at about 12 at steady cruise. with everything off I am right back at 14. Mean green is EXPENSIVE!!!!
11-18-2008, 08:20 AM
#6
yea i know its almost not worth it! but i want it so BAD! but its like $460
11-18-2008, 11:13 AM
#7
I don't think you'll ever find one big enough to power all that at once. My 12,000 pound winch (6.6 hp) draws 450 amps at full load.
Go with as big of an alternator as you can reasonably go and when winching, turn off all lights, fan, stereo, anything electric, and rev the engine. The battery will still drain so you'll have to winch in intervals, letting the battery charge in between.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
11-18-2008, 04:32 PM
#8
I have one. I have a massvie sterio drain,lights, and all taht junk and it didnt hold up at all(the stock one). Bought new one for right at 500. Does fine now.
99 WJ Black on Black on Black
4.7L V8,20x10 Wheels,33/12.50/R20 Nitto Muddgraplers,6.5" IRO Long Arm Kit,Flowmaster 50 SUV Series Exhaust,4 10" Memphis M3 Sub's In Slot and Port Box,2000 watt Memphis Bell Amp,300 Amp Alterantor,Memphis Amp Kit,5% Tint All The Way Around,Black Projector Lights,Black Projector Fog Lights
11-18-2008, 05:10 PM
#9
Is it the Mean Green or whatever its called?
11-18-2008, 06:10 PM
#10
MeanGreen....
11-18-2008, 06:22 PM
#11
Mean green + dual batteries duralast golds 1k cca dual would be cool or 2x odyssey battery
11-18-2008, 06:31 PM
#12
yea thats alot to have to do.. Grr.
11-18-2008, 06:32 PM
#13
I also have 2k watt amp. 2 Compas. 2 yellow tops. and the alernator
11-18-2008, 06:37 PM
#14
Jeremy do you have anymore pictures of your jeep?
11-18-2008, 06:42 PM
#15
I can take some will asap. Camera broken atm
