high oil pressure - JeepForum.com
post #1 of 5 Old 06-24-2003, 03:59 PM Thread Starter
tbone31
high oil pressure
on my jeep my oil pressure is right to the max when i first start my truck when it gets going after awhile it drops down to about halfway? is there any concern here or is it normal, it has just started doing this after i changed my oil last.
White 2001 Grand Cherokee Limited, Tan Leather, Alpine Deck, 1001 bd and 851x RF amps, Diamond Audio components, 2 12inch RF Subs. 3inch Exhaust.
1993 zj laredo FOR SALE, check the for sale section for details. or email
tbone31 is offline
post #2 of 5 Old 06-24-2003, 05:43 PM
brad335
I had this happen to me once, this might be the case for you. When you change your oil filter, the oil pressure sensor is right next to the filter. If you bumped it, or broke it(in my case) this would most likely cause that to happen. I think mine was like 20 bucks for a new sensor, so its not the worst thing you could repair on the Jeep, but look in to it anyway. Hope that helps some.
~~Brad~~
brad335 is offline
post #3 of 5 Old 06-24-2003, 08:15 PM Thread Starter
tbone31
thanks man it makes sense and hopefully thats the problem i will check it in the morning and if thats not it i guess i will be back for more help.
tbone31 is offline
post #4 of 5 Old 06-25-2003, 09:08 AM
automan25
My oil pressure gauge has always behaved that way. It runs between 60 and 80 on the freeway, and about 30-40 at idle. Like yours, it also runs higher when the engine is cold. I always figured this was due to the oil being thicker; that as the oil thinned out with heat, the pressure dropped. How was your gauge reading before you noticed a change?
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #5 of 5 Old 06-25-2003, 02:51 PM Thread Starter
tbone31
before i changed my oil it behaved sort of the same way it would move around as the truck got warmed up or when driving on the highway, it just had never been all the way to the max when i started it
tbone31 is offline
High oil pressure ry1820 ZJ Grand Cherokee Forum 14 12-12-2009 09:01 AM
high oil pressure Arcticcat843 ZJ Grand Cherokee Forum 12 07-26-2009 06:00 AM
High Oil Pressure Texas WJ ZJ Grand Cherokee Forum 7 11-22-2006 08:47 AM
High Oil Pressure IN99WJ ZJ Grand Cherokee Forum 2 12-01-2005 09:31 PM
Oil Pressure High OrvisOwner ZJ Grand Cherokee Forum 1 09-07-2004 12:12 PM
