High Oil Pressure - JeepForum.com
post #1 of 10 Old 03-26-2013, 08:11 AM Thread Starter
Compgeek789
1994 ZJ
High Oil Pressure
I have been searching all around the web for a reasonable cause, but couldn't find anything. Last summer I was having electrical issues, but the oil pressure gauge was reading dead center, barely any fluctuating. Then, the mechanic screwed a bunch of crap up and nearly destroyed it trying to fix a starting/stalling issue. But after he worked on it the mechanic started the vehicle and the oil pressure gauge soared to 60~80. I tried to ask what was up with the pressure, and he ignored the question. While running cold, it stays there, and most of the time while running hot. When accelerating, the oil pressure goes either a little bit down or a little bit up. The needle also seems very twitchy, and it has maxed out over 80 PSI a few times. I use Castrol Edge 10W-30, and get my oil changed every 3500 miles. 212,000 miles, 5.2L engine. Could this possibly be due to sludge, sensor or pump issues?
Compgeek789 is offline
post #2 of 10 Old 03-26-2013, 08:35 AM
GotMoose
1994 ZJ
The oil pressure sending unit is a really cheap design and not very reliable. Rent or buy a mechanical gauge to check for any issues with the oil pressure. I've changed my sending unit 3 or 4 times over the years. When they are about to fail, they can give extremely high or low values or a twitchy needle. If the internal membrane (which is plastic or rubber) rupture, it will start leaking lots of oil.
GotMoose is offline
post #3 of 10 Old 03-26-2013, 08:39 AM
KoreaZJ
1994 ZJ
Check the connection is clean and tight.
Measure sensor resistance...
0 psi = ~1 ohm
40 psi = ~46.5 ohms
80 psi = ~87 ohms
KoreaZJ is offline
post #4 of 10 Old 03-26-2013, 11:35 AM
JohnnyZJ
high pressure = fine
low pressure = worry about it
if it WASN'T up there i'd be concerned
07' JKUR rollin on 35s
JohnnyZJ is offline
post #5 of 10 Old 03-26-2013, 03:36 PM Thread Starter
Compgeek789
1994 ZJ
Ahh the thing goes all over the place, but mainly high. I will check the sending unit to see if it works, and borrow a pressure gauge from the school's auto shop.
post #6 of 10 Old 03-26-2013, 03:44 PM
wwch99tj
Does it read 0 when the ignition is on engine off?
Mine reads almost 20 with just a ignition on, almost 80 going down the road...
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #7 of 10 Old 07-13-2013, 08:28 PM Thread Starter
Compgeek789
1994 ZJ
I think it is either a connection problem, sender or gauge itself if you read 20 psi when the ignition is in run position with engine off.
RIP 1994 ZJ 5.2
post #8 of 10 Old 07-13-2013, 08:46 PM
wwch99tj
I have since replaced the sender and everything is normal now.
wwch99tj is offline
post #9 of 10 Old 07-14-2013, 05:55 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
If you replace the sensor I would get a Mopar. I bought an aftermarket one and barely tapped it while working and the top popped off. Holding the two in your hand, you can see the manufacturing differences.
Originally Posted by HighLonesome
coralman is offline
post #10 of 10 Old 11-07-2014, 11:07 PM
SweetPEALvr15
Ok I'm having the same problem and I replaced the oil pressure sending unit on my 4.0 per advice I've searched on here but my gauge is still going crazy just as the original poster said yet my problem is persisting, any ideas? this occurs in conjunction with my jeep shuddering and feeling like it wants to die when I'm not pressing on the gas. really stumped and frustrated after I've replaced bad upstream O2 sensor re sealed both valve cover and oil pan.
SweetPEALvr15 is offline
gauge , oil , pressure , sensor
