High Milage Transmission Flush - 96 ZJ - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > High Milage Transmission Flush - 96 ZJ
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 02-04-2013, 08:59 PM   #46
josephsproles
Originally Posted by herqulees View Post
As I said before that piece looks like an exact fit, only way I could tell you exactly is if I had it in my hand but superglue has held mine for over 5000miles now which broke the exact same way as yours.
As LouC said fix it with super glue and order that one as a back up.
I shall superglue if the replacement isnt available/won't work... hope it works out either way...
josephsproles is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 02:58 PM   #47
josephsproles
so on the 96 4.0 for some reason they put an "extended" plastic piece on the end, allowing the use of around 1.5-2 inches less cable, thus, when it breaks, using the cable end I posted, it will be completely pulled tight without the throttle extended, meaning it is of no use! HAVE to replace it on this cable, so I went ahead and orded the "clip" style cable rather then the push button self adjusting... NOW... HOW do you install this cable and uninstall the old one without dropping the pan? I have read on a bunch of forums that you dont need to drop the pan... NOT driving the ZJ is KILLING ME... Help.
Unread 02-05-2013, 05:20 PM   #48
herqulees
The kick down cable has nothing to do with anything in the oil pan, it's just a cable pulling a lever on the side of the transmission, just follow the cable and you'll find the other end. Three options;
1. Super glue the old piece back together.
2. Buy the new cable end and cut 1.5 to 2inches of sheathing off the cable allowing it to move more.
3. Buy the entire new cable and replace it.
If you MUST replace the entire cable and want the instructions I can scan them out of my Haynes book and post them here for you, but as I said before I recommend just super gluing and forgetting about it, you're worrying about a small thing too much.
herqulees is offline   Reply With Quote Quick reply to this message
high mileage , seafoam , transmission fluid , transmission slipping , zj
